Volks AutosEM Tuning
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    265
    Bore finish after re bore
    Does any one who has Elsawin know what finish the bore needs to be after a re bore?
    The finish should have a number, ie type 32 finish,usally has a tranangle symbol after the number.
    Obviously i will be honing the bore after machining but need the get the right machining perfections in the bore before hand.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Honing specs are normally on the piston specs assuming you are going for aftermarket pistons... they were on my CP pistons...
    <tuffty/>
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    265
    Cheers Tuffty but i`m after the oem spec of the block, i don't have Elsawin but i`m assuming the bore finish spec should be in the technical data? Like Service limit.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    Had a quick look but elsa is a bit vague... maybe more data there if I dug about but not had time at the moment...
    ..and as an example... mine from my CP pistons..
    <tuffty/>
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    265
    Cheers dude for finding that.
    basically it tells the machinist what cutting speed is required, Bit spec e.t.c
    i would imagine the smoothest finish available, ie type 32 finish but then again your gonna hone it afterwards so that`ll ruin the type 32 finish anyway.
  1. Hazey finish after hand polish
    By Rigla in forum Detailing
    Last Post: 4th September 2010, 13:02
  2. Bored on a Thursday night.....
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2004, 01:03
  3. I'm bored...
    By AlexStanley in forum General Chat
    Last Post: 31st October 2003, 17:16
  4. I was bored!
    By XXX_18T in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2003, 13:08
  5. Bored
    By Drystone in forum General Chat
    Last Post: 7th January 2003, 12:01
