Badger5Chris Nott
Results 1 to 7 of 7
    epox's Avatar
    Oct 2012
    Glasgow
    561
    any posts / how tos to replace the seals on rear calipers?
    as post, just nacked the rear seals, or any good places to get calipers?
    thanks
    mark
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    592
    Never seen a how to, but they are easily done.
    You have to screw the piston out & will usually find some corrosion in the back of the original seals.
    A good clean out with a tooth brush & scriber if need be, followed by a blast through with contact / brake cleaner.
    The pistons themselves should easily clean up with a wire brush etc.
    You can get the seals through the Audi parts dept & re-assemble using silicone grease.
    Then its the usual process of fitting & bleeding.
    ...... Now this one's MUCH better!...
    Mar 2013
    Devon
    563
    Quote Originally Posted by epox View Post
    thanks
    mark
    Got my seals and new guide pins / boots from here, about a quarter of the price of the dealer:
    Audi A3/S3 Brake Discs - Audi A3/S3 Brake Pads
    epox's Avatar
    Oct 2012
    Glasgow
    561
    thanks, is it 41 or 38 seals for the s3?
    mark
    chris99's Avatar
    s3 driver
    Dec 2010
    54
    original PN is 8D0698671.. 38mm as i remember, but can check in a few hours as i have a spare kit around
    Audi S3 8L
    OZ Superleggera | Bilstein B14 | BMC CDA | K04 | FMIC | SACHS Race Engineering | Brembo Sport GT | EBC Redstuff
    Live to drive, drive to live
    chris99's Avatar
    s3 driver
    Dec 2010
    54
    Quote Originally Posted by chris99 View Post
    38mm is the one you need for S3
    payed much more for an OEM repair kit which is also TRW
    Audi S3 8L
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    741
    So is the 41mm for the A3 (non S3)? I'm tempted to replace the seals as I just can't justify the cost of new calipers if a seal kit is a fiver...
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
  1. Any "how tos" showing how to fix the 1998 A3 seats?
    By luckymacy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2009, 01:39
  2. How do I replace the rear window brakelight bulbs? (Saloon)
    By jonnycraig in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th July 2009, 23:17
  3. How do i remove the front and rear bumpers
    By BromleyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2005, 16:37
  4. How easy is it to replace the aerial on my S3?
    By bigshout in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2005, 17:50
  5. Replacing the gear knob, how do you get it off?
    By imported_G4JSG in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th September 2004, 17:34
