Chris NottVolks Autos
    Jul 2013
    26
    noise after start up. please help!!!
    Recently my 1999 1.8t Agu has been making a noise after start up. Sounds like the starter motor not disengaging. However, the noise seems to be coming from the right of the head of the engine. After its started it idled very low, if the car is revved, the car either cuts out or revs to a maximum of 1500 then drops the back to 1500 then drops. Eventually it will cut out. The car is not drivable and its stuck at my workplace. Any help please?
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    282
    You tried bump starting it so not to use the starter motor? then let it idle
    check for split or separated hoses. The 1.8t`s has allot of vacuum hoses allover the place
    Big Al's Avatar
    4wd + turbo = fun!
    May 2011
    West Midlands
    226
    Check your alternator? Use a long screwdriver on parts of the engine, listening through the handle end onto your ear. Take care, but this will help narrow down the location of the noise. Check your alternator charge using a multimeter. Any garage can check this for you too. Let us know how you get on!
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,046
    Sounds like the MAF tbh... AGU's tend not to run well if the MAF has gone... can you get a fault code scan of some description? first place to look tbh...
    <tuffty/>
    hoffmanvp3's Avatar
    Sep 2013
    Oldmeldrum
    282
    Try unpluging the MAF and see if it runs better?
    Jul 2013
    26
    You're right tuffty. Had the garage round the corne. From me have a look at it. They said they cleaned and reprogrammed it. Runs fine now. Will see how long it lasts for
  1. Problem started tonight... Please help...
    By v1kkm in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd May 2012, 17:07
  2. Cut out at traffic lights and won't start again..please help!!
    By rlc1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2010, 08:32
  3. Grinding noise after starting car
    By Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2009, 13:11
  4. please help. is this noise from suspension ?????
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st October 2003, 21:19
  5. Consistent TICKING noise? Please help!
    By 97AUDIA418TQ in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd October 2003, 22:04
