Monster MotorsportBadger5
Results 1 to 23 of 23
Like Tree1Likes
  • 1 Post By Grahamb
Thread: My First Audi - Help!
    J44KWED's Avatar
    Sep 2013
    West London
    46
    Post My First Audi - Help!
    Hi all,
    I'm new to this blog but have read many interesting posts already and I now have a very expensive shopping list so thanks for that!
    About a month ago i bought a blue 1998 Audi A3 1.8T full leather with 88,000 miles on the clock. It had recently had a new gearbox, cam belt, clutch, solid mass flywheel conversion, fuel & water pumps. So I was fairly happy i got it for just under £1,000 The reg also begins 'S3' I wish it was an S3!
    I bought the car as standard, and put some 18" ZCW ZM5 wheels and Maxxis Pro R1 tyres on within a week of having it. It's been a great car so far, but I've found a couple of things wrong with her since.
    The last MOT (April 2013) said that both 'nearside & offside bonded suspension unit is deteriorated but can function as intended'.
    Is that this?:
    The car pulls to the left if i let go of the steering wheel, to drive straight i have to steer slightly right! I've had the alignment checked twice but they said it was all properly aligned, so I'm thinking it must be the bonded suspension unit. Anyone else had this issue? The tread on the left front tyre was severely worn on the very edge when i bought the car and don't wanna wreck my new tyres!
    Also just tonight i was having a poke around the engine bay, and found that a hose coming off my stock dump valve has broken (if that's what it is) the lower end was completely separated, and when i touched the hose, it completely came off in my hand! Oops. I've been driving with it like this fine, and i can hear a dump valve whoosh noise when i change gear and hadn't felt any problems driving it- Can anyone advise me what that hose does and if i should replace the DV with an 007p while I'm at it?
    Here it is:
    Thx in advance!
    p.s. I'm based in West London if anyone can recommend a good garage?
    Cheers,
    Jack.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,463
    ​Hi Jack, welcome to audi-sport.net. Im sure you will enjoy the forum. x
    J44KWED's Avatar
    Sep 2013
    West London
    46
    Managed to find out how to add photos:
    Car when i bought it..
    Car now I've added the wheels:
    rear bonded suspension unit?:
    DV issue:
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    Oh that DV wants sorting! Run a new vac feed to it, as in replace that split pipe ASAP. Just buy a new standard one to for about £35-£40, they often work better than Forge. If you don't sort it, you could end up doing some damage to the turbo as it can't correctly dump the excess boost when you change gear or on the over run.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Vex182's Avatar
    Apr 2012
    Hinckley
    879
    I can't help you with the suspension though, sorry!
    J44KWED's Avatar
    Sep 2013
    West London
    46
    Christ! thanks for the heads up Vex, god knows how long its been like that!
    Jul 2013
    70
    You must be able to hear that suspension, as above with the pipe, man that needs sorting
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,069
    Visit 16Klappe's Instagram Channel
    Read this thread.
    Must do modifications for K03/K03s AGU and AUM engines FWD cars
    Do the N249 removal.
    Have the rear beam bushes replaced, they aren't a fun job but they make a big difference.
    And clean the engine bay, looks disgusting.
    Welcome to ASN.
    I quite often say I'm going to do things.
    Then never do them.
    Jul 2013
    70
    Do the fancy stuff last get the car running correctly first
    s3dave likes this.
    J44KWED's Avatar
    Sep 2013
    West London
    46
    Thanks guys,
    Will get my rear beam bushes sorted asap. I've been quoted £120-£150 per side..
    16Klappe - I can't see the N249 in my engine bay.. is it somewhere else on mine or you think it's been removed already?
    Just off to get some new 4mm piping..
    Also, my glass bung arrived from wiper blanking plug. wiper blanking grommet. de-wipering. wiper delete. - Wischerloch cleanen. Heckwischer entfernen. yesterday so I de-wipered her this morning.. and i think i might debadge this afternoon too!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,374
    '98 will be an AGU engine code and wont have an N249.
    Get a new standard DV (710N from S3) and fit that with some new vac line.
    If you debadge it, leave the rings on, it looks weird without them. Or you can get nice gloss black rings from ebay which look smart!
    TD5 Land Rover Defender build
    Tovs's Avatar
    Sep 2013
    East Anglia
    168
    Turbo and suspension, needs sorting ASAP to prevent other damages occurring, especially the turbo, might Dump in itself, causing your turbo to fail, then costing you mega bucks, rather than a few quid
    Tovs
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    Quote Originally Posted by Grahamb View Post
    Love how some folks jump straight into modding when the cars not right in the first place...
    You cant polish a turd!
    As above, get it up to scratch first before the rest.
    I'd say any car that's needed a gearbox at that mileage has already been well abused & neglected tho.
    ...... Now this one's MUCH better!...
    J44KWED's Avatar
    Sep 2013
    West London
    46
    Yeah apparently the diff went in the old gearbox. I hope to give it TLC from now on!
    Thanks for the heads up though guys, I've fitted a new hose this afternoon. Does seem to be a bit sharper on acceleration/gear change now, but then again that might just be because I've been driving the missus' 1.2 Fiat 500 around. I'll get the suspension sorted asap. Pay day next week!
    Tovs's Avatar
    Sep 2013
    East Anglia
    168
    Quote Originally Posted by J44KWED View Post
    Needs some serious TLC, a good clean out of the engine bay that's for sure. I'd advise to keep it on a standstill till the suspension is sorted, to lower the risk of further damage.
    Fiat 500 it is! Beast
    Tovs
    J44KWED's Avatar
    Sep 2013
    West London
    46
    I'm pleased to mention I've found a reputable VW/Audi garage in West London that will replace both Rear Axle bushes for £150! Booked her in for tomorrow. Just going to have standard Audi bushes to replace, don't want to risk making the ride too firm with the Polybush ones. :-)
    Nov 2011
    W. London
    63
    How's it goin Jack, that BP looks very familiar, where did you book it in, in the end if you don't mind me asking?
    Sorry I couldn't recommend anywhere myself as i've never been happy with any of the garages i've been to except when i went to west london audi for a fixed price service and that was only because of the amount of times i was called sir and Mr ... was worth the premium alone
    D
    J44KWED's Avatar
    Sep 2013
    West London
    46
    Volkswagen Specialist London | VW Garage Heathrow | Middlesex Service VW - Hestonvw.co.uk
    Rang em up to see if they do Audis too and they do. They've got good reviews, and sound quite nice. Plus they are cheap! Suppose I'll find out tomorrow if they're any good or not.
    J44KWED's Avatar
    Sep 2013
    West London
    46
    Picked the car up tonight after having the new rear axle bushes fitted for £200, car feels much better over the bumps (no massive thud at the back any more). Next on the agenda is to replace top mounts and ARB bushes.
    Any members living in West London area I would highly recommend hestonvw.co.uk
    Tovs's Avatar
    Sep 2013
    East Anglia
    168
    Hopefully it holds out! Good job
    Tovs
    Jun 2012
    Redhill Surrey
    635
    Add Grale1 on Facebook
    I have a similar problem with my car always going left and having to hold the wheel to the right, mine feels loose on the front also. I've had 4 wheel alignment a few times and it's always good, in the last few months I've been told that it's my diff on the gearbox is knackered, how true this is I don't know, hope you get yours sorted
    A3 1.8t AGU, fk ak street coilovers, silicone tip, silicone turbo outlet pipe, forge 007p ( yellow spring ), 80mm jetex cone filter, 3" cold air feed, 3" downpipe and de cat, R-tech stage1 map 187bhp- 227ft
    J44KWED's Avatar
    Sep 2013
    West London
    46
    Oh damn i really hope it isn't the gearbox!
    My gearbox isn't very smooth actually, quite hard to get into 1st at the lights and tough going into 2nd too. Takes its toll on my left shoulder after a while, and I don't have small shoulders either. Was thinking of replacing the dog mount to see if that helped. I read a few posts on here saying it did help some people giving smoother gear changes. Worth a try for a cheap part i think.
    Jun 2012
    Redhill Surrey
    635
    I put the red one in, made a little difference on mine but I know my box needs changing and the driveshafts on mine will get done at the same time
  1. Replies: 32
    Last Post: 7th August 2011, 16:40
  2. Looking to buy my first audi! but need help
    By S3 MRU in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th August 2010, 22:04
  3. Help new purchase first Audi
    By Xattica in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th December 2009, 03:35
  4. Help buying first Audi please.
    By willie in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st January 2007, 23:17
  5. Looking to buy my First Audi, need help...
    By EBZ in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd November 2004, 18:19
