EM TuningSky Insurance
Results 1 to 35 of 35
Like Tree2Likes
  • 2 Post By vrbob
Thread: After run pump - when should it be on?
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    So, I'm curious about the after run pump on the S3. I can hear it come on when I turn the ignition, but it doesn't always come on after I've been out in the car. Does it only come on if the cars in a given temperature range or something, or do I have a problem?
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    It should always run as it supplies coolant to the turbo, then run for the set time when the car is turned off.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,160
    Quote Originally Posted by [Dave B] View Post
    Mines the same. Sometimes if I just turn the ignition on but not the engine it'll run. Other times I can start the car on te drive to put it in the garage and the pump won't come on!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    824
    Add Vex182 on Facebook
    Agreed, mine is nearly always on when the car has run and sometimes even when the engine has not been turned over, runs for around 10 minutes or so.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, N249 bypass, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    I had a listen last night. Turned the ignition on and the pump came on. Turned the key to off, and the pump stayed on for about 5 minutes. I hope this means its working as Vag intended. I'm going to keep an eye on it every time I use the car now...
    > S3 225 (03) - OEM+
    View: My S3 diary
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    It should run 5-10 minutes(never timed it) every time the engine is switched off by the keys in the ignition.
    You've got to have a laugh!
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Ok, so if it's only coming on intermittently (which I need to confirm as I'm now questioning my own sanity), then I'd expect its an electrical issue (relays, connections etc)?
    > S3 225 (03) - OEM+
    View: My S3 diary
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,640
    It seems hit and miss for me, even with a known good pump. Some days it runs, others not.
    Is it loud? Mine was loud pre-clean. It's easy enough to take it off and clean it out. 4 screws to remove the "turbine" section and then they'll be bits stuck to the magnets which are behind the plastic housing. Hard to explain but you'll see once you have it apart. Cleaned mine up and it's whisper quiet but runs intermittently.
    I have another brand spankers replacement to go on tomorrow. I got this one: Mopar Electric Auxiliary Water Pump 2007 2009 SRT4 Dodge Caliber 05047003AB | eBay (best offer $50 accepted) It's Bosch and brand new. Marginal difference in the hose tail sizes (19mm vs 20mm VW) but for the price difference, can't complain. I'll fit it tomorrow and let you know if it changes anything.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Yohan87's Avatar
    May 2011
    404
    On my Bora 4motion even if you turned the ignition on but not the engine, then turned it off again the pump would run.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    Yup mine goes for 10mins or so everytime you turn on the ignition (engine does not need to start)
    Quick warning to anyone wanting to service their pump, my original one was leaking so bought a cheapo second hand one off ebay for £20. It was defo in better condition than mine so put it on and its ok so decided to try and clean up my old one as a "backup" The 4 screws are a pain in the bum to remove as they become one with the plastic casing through corrosion and the heads snap off very easily!
    I managed to hack my old one apart with a hacksaw in the end and now have some bolts holding it together if I need to use it again.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    I would remove the connecter plug and test it for voltage while the ignition is on and when its turned off. Would also do this test a few times to see if it an intermittent problem with the wiring. If all is OK then remove and check the pump or supply voltage direct to the pump terminals. Be warned though the inlet and outlet are probably brittle and might break off while you try to remove the hose.
    Westy's Avatar
    Dec 2008
    17,160
    One of the 3 green fuses on top of the battery is for the pump and these can also have mucky connectors. Mine stopes working completely once and it wa down to a poor connection at the fuse.
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    Perhaps theyre a bit more complex than 'they should run after every running of the engine. Maybe it depends on other things and sensors etc, no one seems to know exactly
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,640
    I agree Karl, I don't think it always has to run. It might be temperature based. It'd be good if there was some solid evidence either way really.
    Westy's Avatar
    Dec 2008
    17,160
    I was swapping my brake light switch yesterday on a stone cold car an I was cycling the ignition. Pump was comming on so it's definitely not temp related!
    S3 Build Thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    The after run pump should run whenever the keys have been in the ignition and primed, even if you dont fire the engine the pump will run, I bought a brand new pump and prior to that it would be intermittent like some of you guys are getting.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    It'd be good to get a definitive answer on this, although I don't know quite how we'd do that. I've had a look in the owners manual but there's nothing in there (as you'd expect I suppose). I haven't been out in mine since so have nothing to report. It definitely comes on and stays on when the ignition has been turned on and off though.
    > S3 225 (03) - OEM+
    View: My S3 diary
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,640
    Fitted my new $50 Bosch after run pump for a Dodge Caliber SRT4:
    The downside is it has 19mm tails rather than 20mm but the hoses clamped up fine and haven't leaked. Seemingly it's been on after every drive now so maybe the old one was infact knackered? The one that was on there (the one I made out of two good pumps) did run when I moved the car out of the garage to fit the new one but who knows. I'll check when I get into work tomorrow morning and see if it runs.
    A bargain if anyone needs one:
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    If it doesnt run, how is the turbo going to get coolant to cool it? Now go have a beer and think about your answers
    I used a pump from a A4, it turned out the flow was the opposite way round. So if you get an aftermarket pump or retrofit a pump, make sure you check the flow direction. You dont want the pump not suppling coolant to the turbo.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,640
    By driving at a leisurely pace before shutting off I guess. I try not to thrash it to death and then just stop and turn off. Always a good few minutes of granny driving. The pump would also render a turbo timer pretty useless wouldn't it?
    That Dodge one is the same flow wise as OEM. Just way cheaper like the Vauxhall ones in the UK.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    The dodge pump linked above is a bit costly to us UK peeps due to the cost of postage p0lus any import tax they whack on.
    So just found this BOSCH additional electric water pump for engine cooling/car heating/ 0392020034 | eBay on Ebay and looks like the same thing for £55 delivered (basically half price of a Audi one) plus it has 20mm outlets like the OEM one so could be a good alternative.
    Also I spotted in another thread regarding these pumps that they think the CTS has something to do with the pump running on the car but I cant confirm or deny this
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,640
    That looks ideal! The 19mm tails thing seems like a minor issue anyway but better to stick with 20mm. The other thing that can be different is the connector. It varies what type they have but the one you linked looks spot on.
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    Yup comes from Latvia and takes a few weeks to get to the UK but for the price it looks good so as my second hand one is working (all be it a tad noisy) I think I will take a punt and get one as have the bracket off my old pump to use so should be good to go
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Great find, it'll be interesting to see what difference it makes, if it's significantly quieter let me know as I might invest in one for that reason and to have more confidence in it.
    I was out in mine yesterday and had a listen at a few different times to see if it was on. After a very short run using hardly any boost I stopped the car and it wasn't on, after a long run with plenty of poke it was on, both when the engine was running and when the engine was turned off......the system is either intermittent by design, or the pump is on its way out because of age or there's some other electrical gremlin at work.
    > S3 225 (03) - OEM+
    View: My S3 diary
    Feb 2006
    Lincolnshire
    692
    The pump should run after removing the key from the ignition, even if the engine hasn't run, but assuming ignition was turned on.
    Mine used to stop working intermittently too. If I tapped the pump with a hammer, it would often start which pointed to it being a dodgy pump.
    I picked up up a new pump from TPS last week, fitted it and now it runs every time the key is removed.
    Audi S3 - 2002MY - Denim Blue
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,640
    Yep, can confirm as above. Mine seemingly runs after every drive or ignition on/off. It's way quieter too.
  28. #27
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Bummer, seems like I need a new pump then. Thanks chaps.
    > S3 225 (03) - OEM+
    View: My S3 diary
  29. #28
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    A bit off topic, OK OK completely off topic
    Quote Originally Posted by Sam_ View Post
    for me the turbo timer just allows everything to "cool" down while the engine idles for a few minutes. Had a look at the EGT last night, normal driving around town the EGT was just above 600c. So if I turned the car off, the turbo, exhaust mani, and head would be fairly warm. After the turbo timer ran for 3 minutes the EGT was down to 385c when the engine turned off. Will try 4 minutes to see if it can cool down anymore.
    Just trying to save my turbo for as long as possible, plus it make me look so Gay-DM
  30. #29
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,640
    It is kinda on topic since the after run pump is an OEM equivalent to a turbo timer to cool every thing down after the engine has been shut off. Turbo Timers aren't legal here anyway. Well, leaving your car running unattended isn't and you'd look a bit of a dork waiting for the car to shut off standing next to it. It's probably a little different there in Dubai but I'm pretty sure I don't see 600c poodling around town and the UK barely gets above 25c so no problems there
  31. #30
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Most effective way of preserving your turbo is to coast home/drive off boost the last mile, than rely on a turbo timer/coolant pump!
  32. #31
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    Quote Originally Posted by jojo View Post
    Is there a trick to doing this? I find it very hard to cruise anywhere. The motorway is about the only place I cruise as there are cameras everywhere.
    As soon as I get off the motorway its.....
  33. #32
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    Well just had a message saying my Latvian pump is on its way
  34. #33
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Quote Originally Posted by Scullies View Post
    Just drive normal, not fast for the last mile home, how hard can that be? Surely you warm your car up before you cane it, you just cool your car down with a bit of short shifting driving. No accelerate = no boost = no heat generated on turbo.
  35. #34
    vrbob's Avatar
    Jun 2007
    Southampton
    2,285
    *Update*
    Righto, Had a bad back the last few weeks so not been doing much on the car at all but my Latvian Bosch generic after run pump had arrived earlier this week so I was keen to fit it.
    The pump itself is identical to the OEM pump it just does not come with the little bracket/holder that goes around the motor and attaches it to the car.
    So as I know its a quick job and am not in too much pain at the mo I gave it ago this afternoon. Took about 20mins to swap over (car was almost cold) and quick check with ignition off and then on again (no engine start) pumps runs lovely and quiet.
    So all in all for £55 delivered compared to the Audi OEM price its defo worth doing if your pump is noisy, intermittent, leaking or broken
    Link to the pump on ebay BOSCH additional electric water pump for engine cooling/car heating/ 0392020034 | eBay
    <tuffty/> and Westy like this.
  36. #35
    Jun 2013
    Hampshire
    32
    Evening all,
    where does the after run pump live? I've never been aware of mine running and it's always bloody hot under the bonnet in comparison with the S4 and RS4 I've owned.
    As an aside, on the S4 and RS4 the auxiliary coolant pump only comes on when the ignition has been turned off and the coolant is above a certain temperature. A common mod is to change its sensor for a lower temperature one. The coolant flow is in the opposite direction to the normal coolant flow.
    Is there an S3 self study guide from Audi, for their technicians, as there is for the 2.7twin turbo engine in the S4 and then another for the RS4? Those explain how all of that stuff works.
  1. S3 8L after-run pump
    By dancuz in forum For Sale/Wanted - Audi Parts
    Last Post: 10th July 2012, 19:09
  2. After Run Pump - Can You Set How Long it Runs For? (Battery Died)
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2011, 11:06
  3. After run pump and fans, not working.......
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2011, 18:43
  4. Anyone got a guide to replace the after run pump?
    Last Post: 26th June 2011, 17:25
  5. 2000 a6 after run pump?
    By waltintexas in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 26th December 2010, 16:47
