EM TuningVolks Autos
Results 1 to 7 of 7
Thread: Smoking culprit
    May 2012
    20
    Smoking culprit
    Back again with more problems lol , I've been recommended a decent mechanic locally who I'm going to see soon but before I do is there any way of distinguishing between valve stem oil seal or turbo oil seals in regards to a smokey ride ? Only does it when hot and after I've lifted off the pedal . I've had a brand new head fitted recently so I'm guessing it will be the turbo but I had some issues during said work on head so could do with double checking before I pay out again , £2850 spent in last few months so I wanna hedge my bets if possible . Cheers guys n gals . P .
    Jan 2011
    northants
    165
    if it was a new head then it should have new stem seals
    valve stem seals usually smoke on overrun and when you accelerate after overrun
    turbo smoke can be at idle it does depend on how bad the turbo is?
    just done a turbo on a diesel which smoked when hot at idle and on overun
    May 2012
    20
    The car has done 121000 so I'm wondering if the tubo has ever been replaced , for what it cost i might just replace it and see how I go , if it still smokes then I can send it back as the head is supposed to be brand new ( they lied about testing the head 1st time round refitted it when it was cracked so ad to replace it under warranty ) I'm hoping they fitted new seals
    is the turbo a hard job or is it fairly easy to fit ?
    Jan 2011
    northants
    165
    turbo isnt too bad as long as the bolts come undone
    May 2012
    20
    I'm not too sure which way to go with this one is the turbo a DIY job ? What should I pay for a turbo plus fitting if its not ?i can take the opportunity to fit a bigger or better turbo if its possible ? I don't mind having a go but can't seem to find a thread/guide anywhere relating to turbo removal and refitting . I read somewhere that a blocked breather system can cause issues too so I've just ordered the correct breather pipe as its a bodge job at min thanks for the help so far guys
    May 2012
    20
    Quote Originally Posted by towcestervag View Post
    from that description it's the valve stem oil seals , I'm going to monitor it for the next few miles so I can be more definate . But I'm still playing with the idea of a new turbo just so I know it's been done . The car is a nice car , inside its mint so I'm looking at keeping it for a good while which means at will probably want a new turbo at some point anyway .
    May 2012
    20
    Ok , update time , just been out for a good 25 mile burn , driving hard and fast , leaving it on boost to try and create overrun , guess what , no smoke . Now I'm very confused .
  1. Smoked Rear Light Lenses for 2003 A6 Saloon
    By cliffcartwright in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th October 2003, 14:28
  2. Smoking Kenwood Stereo!!
    By Naresh in forum In-Car Entertainment
    Last Post: 4th October 2003, 00:01
  3. A3 side repeaters smoked
    By FrOgR in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st October 2003, 08:02
  4. Smoking Brakes
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2003, 18:42
  5. Clifford Smoke Alarm
    By Moresauce in forum Other Brands & Models
    Last Post: 11th January 2003, 12:54
