AH FabricationsVolks Autos
Results 1 to 26 of 26
Like Tree1Likes
  • 1 Post By Sam_
Thread: 100mm MAF Housings
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    100mm MAF Housings
    I bought a B6/B7 S4 MAF (same as B5 RS4) for my build which turned up today. On arrival I saw the previous owner had removed the metal mesh which helps remove turbulence from the air passing over the sensor:
    Not ideal but would still suffice. Anyhow, instead of looking for another 90mm housing which I'll have to make some adapters for anyway, I thought about just getting a 100mm housing with the flow straightener built in like this:
    Since I don't need the sensor, just the housing, this might be better option that trying to find another one, making up the adapters etc?
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Well we'll find out when I fit it... Due to the overwhelming feedback, I had no option but to buy the 4" MAF housing with the straightener and see how it goes!
    14nce's Avatar
    Jul 2013
    32
    If nothing else it looks sick!
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,453
    what bhp are you wanting out of your build?
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust, Blue Haldex controller
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    450-500 would be good but for most parts I've planned ahead in case I want more.
    It was more the thought of sourcing another MAF housing by paying through the nose locally or getting it from overseas, then have to make up the adapters for the 90mm or just getting this one and being done with it. Hopefully it'll be ok with idle/low speed.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Quote Originally Posted by 14nce View Post
    Heh, I'll probably just paint it black to look a bit more OEM.
    <tuffty/> likes this.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    If you have idle or low speed troubles, and using a part ali tip, put some flow straighteners inside the tip.
    Its what my mate had to do on his sr20, with a 90mm maf about 10inch from the turbo it was all over the show.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Yeah that 100mm housing has a flow straightener built into it which should help. I might have another RS4 housing lined up though just in case.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Il be using an 90mm rs4 one off scullies. To be honest 90mm should easily suffice and dont think youd be maxxing that out. But if using a 100mm tip you may aswell keep everything 100mm.
    My whole intake is 90mm, plus i dont wana be maxxing the maf
    Jun 2009
    Leeds
    3,453
    You'll find the RS4 maf can flow about 600 bhp. I know mine still has loads more to go.
    Im sure bill or any mapper will tell you the RS maf will be easier to scale in
    FOR SALE
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    It's not a case of worry about maxxing out the RS4 housing. I know that I won't do that. It's a case of what's easily available. Sourcing an RS4 housing locally is easier said than done and finding just the housing for sale elsewhere is a bit scarce too unless you want to pay mega money. I got an alright deal on the one above but as it turned out, it'd had the mesh removed. I'm not convinced the mesh makes much difference compared to the honeycomb proper flow straighteners though.
    There's that issue, plus the fact I don't really have access to any means of making up the adapters for 90mm to 100mm for the hoses.
    I'm interested as to why it would be harder to scale in though? Is it not a maths issue? Working out the area and using that to calculate flow? I'm probably miles off though...
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Scaling isnt the issue with massive mafs. It purely the nature of the air being ever so lightly sucked in such a big void, turbulence screws the low load readings and gives lumpy idle/running.
    Flat out it would be fine.
    I dont think its all that much of an issue the longer the TIP you have as the maf is further away from the compressor.
    If youre wanting a 100mm tip, use the 100mm maf. Worry about the rest whem its mapping time and add straighteners if need be.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Yeah, that was my worry as I posted earlier, the control of idle and low throttle openings and how that can be dealt with when mapping. It's much like fitting too larger venturis in carbs, low air speed makes it hard to meter fuel. In this case, hard to meter the air.
    I've bought the 100mm one anyway so I'll just use it and keep the mesh-less RS4 housing if it doesn't sell locally.
    RIP S3dave
    May 2004
    nr Glos
    7,139
    you are going to try and measure a very low sensor signal when its a small engine with metered air being attempted to be measured within a supersize pipe. It ill be VERY sensitive, overly so, to disturbance as the measurement resolution of light loads, idle, cruise etc will likely cause erratic apparent mass airflow, which in turn will upset the fuel trims and lambda compensations badly.
    Screen is essential as a minimum
    you say its just maths... Not in my experience in terms of RS4 it has'nt been
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    i removed the honeycomb mesh from the standard maf housing & left just the metal mesh in, is that an issue ? doesnt seem to cause one. only a stage 2 jabba map on a K04.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    beachbuggy's Avatar
    Surrey
    1,741
    Quote Originally Posted by mattyboy199 View Post
    as long as you don't remove the sticker you'll be ok!!!!
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    That was my worry. So even with a stroker, at light loads and idle, the air speed is going to be too low to get a decent reading?
    I meant just the scaling being purely maths based, not how it performs. I'm probably miles off?
    When looking at the area size it becomes apparent that the jump RS4 to 100mm is actually similar to S3 to RS4:
    7853.98mm (100mm) 23.457 % increase
    6361.72mm (RS4 ~90mm) 26.563 % increase
    5026.54mm (S3 ~80mm)
    Bugger. Better look for another RS4 housing then.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    The sizes you have quoted are external diameters btw, its internal that matters and that area that needs to be scaled.
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Yeah I know that but I don't have internals to hand. It was more an indication of relative sizes rather than exact numbers but yes you're right, they're external numbers. Do you know the internal figures? Probably -4/5mm or so less, I'd imagine.
    RIP S3dave
    May 2004
    nr Glos
    7,139
    the mesh frotn end should aid laminar flow across the sensor, so who knows.. Which is the problem. No one knows how well it will react or be stablity wise. What I can tell you is if its seeing erratic airflow it WILL cause issues and fueling trims to struggle big time.
    huge pipe.... sensor sensitivity for the low level airflows just makes the thing so much more sensitive to anything other than perfectly stable airflow.
    Screened ftw..
    Sensor resolution for 3-4g/s of idle airflows for example in such a small tube will be very low voltage output...
    It could work ok.. but I dont know.
    bill@badger5.co.uk
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Cheers Bill. I'll give it a go and if it's naff, I'll have an RS4 housing on hand. I've bought it now so might as well give it a go I guess.
    S3 Paul's Avatar
    Oct 2006
    2,764
    What is "Screened "?
    Sorry ive not seen it before this thread
    Noggy Blue 2001 S3
    RIP S3dave
    May 2004
    nr Glos
    7,139
    the entry and sometimes exit of the oe maf tubes have screens to present laminar airflow to the measurement sensor
    bill@badger5.co.uk
    Nov 2005
    UK
    1,688
    Quote Originally Posted by beachbuggy View Post
    sticker ?
    wanted for 8L S3:
    Milltek system
    RIP S3dave
    May 2004
    nr Glos
    7,139
    sticker ?
    hmm
    a certain tuner I wont name here used to stick a sticker over a measurment hole on the maf element to "scale" its airflow..... *cough*
    hmmmm
    bill@badger5.co.uk
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Sounds like when I got my S3. I told the garage I got it from that it had an idle problem that needed to be fixed before I bought it. When I went to pick it up they said "We adjusted the MAF". Suffice to say I took it home and checked it myself. Their "adjustment to the MAF" was to remove the breather hose from the TIP. F'ing cowboys.
  1. maf housing****pleeeease some one have one!
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2010, 21:00
  2. MAF Housing Size
    By johnie72 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2007, 18:48
  3. MAF housing sizes??
    By Biglockie in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th March 2007, 11:00
  4. 2.4 MAF housing diameter
    By mckay9uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2007, 18:15
  5. Larger MAF housing
    By mtsakmakis in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th September 2005, 13:38
