JMB RetrofitsSky Insurance
Results 1 to 7 of 7
    Midlands
    314
    Mirror cap removal
    Hi
    Ive got a new mirror for the drivers side - how do I fit it?
    Car is a 2001 facelift S3 if that makes any difference.
    Cheers,
    Dave
    2001 S3 | 210/256/270 switchable APR software | Absolute Red |
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    The actual Cap or the mirror/glass? The glass part just pulls off, just adjust it as inwards or outwards as you can, and stick your fingers in between the gap and pull firmly with even pressure to avoid cracking the glass, then there's 2 wires you need to pull off. To remove the cap, undo 2 screws at the base and remove the lower plastic cover, and the whole thing just pulls upwards, you may need a flat blade screwdriver to manipulate the clips.
    Midlands
    314
    Cheers, it's only glass to replace so I'll try to remove that only. Not bothered if glass breaks on way out.
    Assume cover only comes off with glass out ?
    Dave
    Midlands
    314
    Do the wires for heating need to match up a certain way?
    Havent tried it yet but the replacement mirror doesnt have any colour coding and the spade connectors are the same size.
    Dave
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    Quote Originally Posted by david7m View Post
    Dave
    Yup, it's easier with the glass out anyways, not tried with glass in?
    Dave
    Nope, just plug and play, never had an issue with which wire is where, it's just 2 wires with the same color connectors.
    Midlands
    314
    Cheers.
    Dave
    Midlands
    314
    Took 3 minutes, cheers.
    Didnt seem to make an obvious click to indicate it was fully on, but it doesnt move and is sat back into the cap per the original one, so I am happy
    Dave
  1. S3 8P2 mirror cap removal - help, how do they come off!!
    By RicoS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th June 2010, 21:46
  2. B5 Facelift door mirror cap removal.
    By knotty in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2010, 23:31
  3. how to remove the mirror caps
    By droppedaudia4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st July 2009, 11:32
  4. How easy is it to remove wing mirror caps for spraying
    By xeryus in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2008, 16:50
  5. wing mirror covers - removal
    By marriedblonde in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th July 2005, 13:08
