AH FabricationsSky Insurance
Results 1 to 8 of 8
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Worrying Brake Warning Issue
    It's basically the major warning light that comes on telling me I have a brake system problem BUT it's only ever come on 3times since sorting my rear discs and pads. The funny thing is it only happens when you turn a tight right bend at "speed". Any suggestions or will i have just a loose brake sensor at the front wheel?
    I am worth checking my ABS in a safe environment?
    Kristian
    No longer an Audi driver...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    Query the ABS controller for fault codes?
    Have you checked brake fluid level? It could be a bit low and triggering the low level warning on corners?
    TD5 Land Rover Defender build
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Fluid level is fine as far as I am aware. Gonna need VCDS me thinks!
    Kristian
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,505
    I had this warning when the brake fluid was on the 'low' marker, the sensor is quite sensitive!
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Unless I need my brakes bleeding properly again... Will check resevoir in morning before I go work.
    Kristian
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    This is becoming a real nuisance now - my brake fluid level appears normal...
    BUT now this warning is flashing up almost every time I turn right and also on the odd occasion I come to a stop and then set off again and even more annoying when in traffic.
    Ever since replacing rear brake pads. This car is really starting to piss me off especially with the way it is always hesitating during general acceleration in low gears.
    (p.s. I am actually fuming with the piece of **** at the moment and its even more so when money position isn't great)
    Kristian
    epox's Avatar
    Oct 2012
    Glasgow
    584
    try unpluging the brake resevoir cables, if the light stays off while driving it may just the the cap sensor thats faulty
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Righteo mate! But why only when I turn right? lol
    And what makes it even worse is I've just had the other half in the car whilst nipping out tonight and there were plenty of right turns yet not once did the warning light flash up...
    STRANGE!!!
    Kristian
  1. Brake warning Light
    By sniperlover in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2006, 21:07
  2. Brake Warning Light After Brake Pad Change
    By iddyarmin in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th May 2006, 20:47
  3. Brake warning on startup
    By imported_VaulterTim in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th January 2006, 14:42
  4. Brake warning Light
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd January 2005, 19:17
  5. Intermittent Brake warning light - WEIRD
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 22:20
