Volks AutosAH Fabrications
    Stevofoz's Avatar
    Aug 2013
    Hockley, Essex
    Follow Stevofoz On Twitter
    S3 Secondary Water Pump
    Hi all,
    I have just been searching through the forum but have been unable to come up with a conclusive answer to my question, hopefully someone can help?
    Should it be obvious that the electric water pump is on after switching off the engine? I can't hear anything from mine and wondered if there is a way to test the unit or if it is 'whisper quiet'!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    It will be obvious if its on... runs for 10mins or so after the engine is turned off... check the fuses on top of the battery as they corrode... one on the left as you look from the front of the car is the fan/coolant pump control fuse
    <tuffty/>
    Stevofoz's Avatar
    Aug 2013
    Hockley, Essex
    Thanks again Tuffty, will have a look this evening.
    Stevofoz's Avatar
    Aug 2013
    Hockley, Essex
    Ok, so the fuses are all intact but at some point in its life someone has put an amp or some such in it as it has a large red power cable running from the far right terminal all the way to the boot. It has had the inline fuse removed so is not live but should there be something else connected to that terminal and could that be the reason why the electric pump is not working?
    2001 S3 Dolphin Grey - Totally Standard...for now....
  1. Secondary Water Pump replacement.
    By Inertiauk in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2011, 11:11
  2. AMK ECU Diagram - Secondary Water Pump
    By Yohan87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2011, 23:27
  3. Secondary Water Pump No Working
    Last Post: 4th May 2011, 07:59
  4. Secondary water pump on 3.2?
    By Wes G in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd October 2007, 17:47
  5. secondary water pump problems
    By stevegti6 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2007, 07:42
