S3 Secondary Water Pump
Stevofoz
Leigh-on-Sea, Essex
Hi all,
I have just been searching through the forum but have been unable to come up with a conclusive answer to my question, hopefully someone can help?
Should it be obvious that the electric water pump is on after switching off the engine? I can't hear anything from mine and wondered if there is a way to test the unit or if it is 'whisper quiet'!
It will be obvious if its on... runs for 10mins or so after the engine is turned off... check the fuses on top of the battery as they corrode... one on the left as you look from the front of the car is the fan/coolant pump control fuse
<tuffty/>
Ok, so the fuses are all intact but at some point in its life someone has put an amp or some such in it as it has a large red power cable running from the far right terminal all the way to the boot. It has had the inline fuse removed so is not live but should there be something else connected to that terminal and could that be the reason why the electric pump is not working?
