Results 1 to 8 of 8
    May 2013
    Glasgow, Scotland
    195
    Car hesitates on low revs ??
    Hi guys was wondering if anyone could shed some light on an issue am haing at the moment.
    Please dont get angry and leave when i tell you the car lol I had an audi until recently and have tried the other thread, but this 1 is hands and feet aboe the "other" 1 lol.
    Ok so its a 2002 Seat Leon cupra, AUQ engine. Its had the s2k airfilter and thats it !!
    There is a bosch MAF in there and still on the OEM DV.
    On WOT it pulls fine, on really low revs in 1rst and 2nd, it sometimes feels like someone has tapped the brakes breifly and then it jjst carries on ??
    No fault codes, no dash lights.
    Just a punt but the other day i thought i heard it dump when t hesitated ?? Possible DV failure ??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Definitely no fault codes? sounds like the ECU is intervening... typically an over boost issue... sounds like throttle cut/boost dump initiated by the ECU to protect the engine..
    <tuffty/>
    May 2013
    Glasgow, Scotland
    195
    <tuffty/>
    Hi tuffy, i was hopng you would reply thanks !!
    The EML is not on so im assuming there would be no flags at the ECU to trigger the EML ??
    I have vcds lite, should l try that ??
    Also i should have said on the initial post, its an intermitant problem its not constant !!
    Thaanks mate
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Just because the CEL isn't on doesn't mean no fault codes mate... scan it with VCDS lite... the meanings of the fault codes can be found at the Ross Tech Wiki (Category:Fault Codes - Ross-Tech Wiki)
    Post the results..
    <tuffty/>
    May 2013
    Glasgow, Scotland
    195
    Post the results..
    <tuffty/>
    Hi tuffty, l was out collecting the wife sorry. Ok i just done a scan, just an auto scan and here are the results:
    VCDS-Lite Version: Release 1.2
    Monday, 16 September 2013, 14:33:06.
    Chassis Type: 1M - Seat Leon/Toledo
    Scan: 01,02,03,08,15,17,19,22,35,36,37,46,56
    Address 01: Engine Labels: 06A-906-032-AJQ.LBL
    Controller: 06A 906 032 MJ
    Component: 1.8L R4/5VT 0003
    Coding: 11510
    Shop #: WSC 80178
    VCID: 729759CB2DB7
    VSSZZZ1MZ3R036000 SEZ7Z0B1625363
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.LBL
    Controller: 1C0 907 379 K
    Component: ASR FRONT MK60 0103
    Coding: 0022017
    Shop #: WSC 00001
    VCID: 321799CBED37
    May 2013
    Glasgow, Scotland
    195
    I have a bosch dv from the audi, which i know was 100%. Should l change over and see if it helps.
    I should also add, its just had 4 new coil pack as per the recall. The issue was present beforehand anyways !!
    ManuGD's Avatar
    Mar 2012
    Barcelona, Spain
    24
    My S3 did something similar, close to 2000rpm, and after searching and testing, it was the MAF (one more time).
    Try to swap a healthy MAF and see if it still happens
    May 2013
    Glasgow, Scotland
    195
    Quote Originally Posted by ManuGD View Post
    I had just done 1 on my audi, is there anyway to confirm without buying a new 1 for no reason ??
  1. Stage 2+ S3 low rev hesitation
    By Y444GAR in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th November 2010, 00:21
  2. Car shaking/vibration at low revs
    By rickyquicky in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2010, 20:49
  3. 2.5 tdi hesitating at low revs
    By boya in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th October 2009, 12:36
  4. Car cuts out at low revs, while heavy steering input is made
    By AndymacA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd November 2008, 12:13
  5. Low rev tinkling sound...
    By RichWalk in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2005, 09:32
