Results 1 to 12 of 12
    Bigandbald's Avatar
    May 2013
    Basingstoke
    105
    MOT failure on emmissions??? Help
    Ok so my standard 111,000 mile S3 just failed the MOT on Emmissions. the MOT tester said it was the Lambda sensor but before i go and buy one i just want to make sure it is that and not something else??
    Anyone got any ideas??
    `02 S3 AMK now sold, need more doors so along comes an '04 Seat LCR Bam 225, badger5 tip, s2000 filter, very high mileage now with badger5 remap @ 275.5bhp.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    thrash it and try again
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    AFR is at 0.96 from that printout.. you would need to check blocks 032, 031 and 001 initially to see what the ECU thinks is happening...
    Also check for fault codes... adaption may not be working for some reason... this normally happens if the N249 or post cat lambda is disconnected...
    <tuffty/>
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    There could be multiple issues, have you checked for fault codes?
    First Fast idle test to me looks like the cat isnt working. The Lambda and HC reading is fine, but CO is typical of a decatted car.
    Second fast idle test has gone quite rich, which could mean an airleak, faulty lambda, duff MAF or various other issues.
    Natural idle again looks like the cat isnt working.
    With a working cat, CO is typically almost 0.
    TD5 Land Rover Defender build
    Bigandbald's Avatar
    May 2013
    Basingstoke
    105
    Tuffty...you appear to be the VCDS God here, unfortunately i dont have it and have posted on here before asking for help and no one responded??? happy to pay for someone's time to plug it in and diagnose.
    i had thought about maybe an additive in the fuel or something???
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    As Aragorn said... could be one of a few things... VCDS or at the very least a generic code reader required really to see if the ECU is unhappy...
    Check for split pipes under the inlet manifold... clue will be oil... oil should be in the engine not on the outside... if its outside then its leaked from somewhere...
    If the garage you had the MOT at has a smoke tester it would be a good idea to get that done as this should highlight split pipes more easily
    <tuffty/>
    jamiebennett81's Avatar
    May 2008
    206
    OR
    Take it to a very friendly MOT tester.....
    2001 Seat Leon Cupra. 291bhp 13.4 1/4 mile @ 108mph.
    Click the picture below for my build thread.
    "Stick a V8 in it!"
    14,900
    OR
    Dont, and fix the issues so the engine is actually running properly.
    Bigandbald's Avatar
    May 2013
    Basingstoke
    105
    OR
    MO was jut going to say I can get it through the MOT that's not the problem, but I'm all up for fixing it as my MPG is shocking at best so happy to resolve the issue(s) but need it diagnosed.
    anyone know anyone near Basingstoke with vagcom that wants to earn some beer tokens???
    May 2008
    206
    Quote Originally Posted by Bigandbald View Post
    Prawn can help as he is in Basingstoke or I can as I'm Reading based
    Bigandbald's Avatar
    May 2013
    Basingstoke
    105
    Ill try to get hold of Prawn, if not ill pop you a pm if thats ok.
    many thanks peeps!!!
    Bigandbald's Avatar
    May 2013
    Basingstoke
    105
    PRAWN............HELP!!!!!!!!
  1. HELP!!!!!!!!!!!!!! MOT FAILURE
    By Sm3g in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2013, 21:54
  2. S3 mot failure on emissions please help
    By campbell in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2011, 10:44
  3. MOT Failure - 400 for new headlight!!!
    By GibletsS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2008, 20:14
  4. Mot failure :(
    By mephisto in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2007, 21:47
  5. Is this a MOT failure
    By Mart in forum General Chat
    Last Post: 12th September 2006, 17:20
