Volks AutosChris Nott
Thread: Valve Stems
    May 2011
    Manchester
    Valve Stems
    Does anyone know if the valve stems are any different in an APY head and an AMK head?
    Kyle.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Valve stems? as in actual valves? 20v turbo valves are all (mostly) interchangeable... by mostly I have seen the collet groove height vary between some (AEB head in this particular case) but APY/AMK/BAM should all be the same valve...
    <tuffty/>
    May 2011
    Manchester
    Thank you
  1. CF tire valve stem caps and TPMS
    By woodsman in forum General Technical / How To
    Last Post: 8th October 2012, 14:48
  2. Warped Valve Stems on S3
    By BOSSS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st May 2012, 09:32
  3. Is it possible to change the valve stem seals...
    By audi5e in forum General Technical / How To
    Last Post: 28th October 2005, 00:12
  4. Dump valves
    By waynehiscock in forum General Technical / How To
    Last Post: 28th March 2003, 18:15
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
