EM TuningMonster Motorsport
    Maz
    Maz's Avatar
    Moon is made of green cheese
    Jan 2005
    East
    1,008
    Oil on Ignition Coil
    Hi all,
    decided to do the N249 bypass today which I managed with ease thanks to the various guides on the forum.
    Also managed to replace some perished hoses with some Forge items which was nice m easy.
    Coil packs were also going to be replaced with some red top versions but I noticed a little oil on Coil 2 as I pulled it out and Coil 3 was dripping in the stuff.
    Can any of you tell me why this has happened and what needs to be done to resolve it.
    Thanks.
    Mineral Grey [
    AMK
    Lewis583's Avatar
    Mar 2010
    870
    The cam cover gasket comes in two parts.
    * One a long thin rubber ring which seals around he outer edge of the cam cover.
    *The other is a chain of rings which seals the cam cover around each of the spark plug/coil pack holes.
    It will be the chain of rings gasket which will have gone hard and no longer sealing. New cam cover gasket required bud. Both gaskets come as a pair.
    Link to eBay gasket
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    Thanks bud,
    I'll get on the phone to TPS tomorrow.
    One small job, turns in to another and another...
    Mineral Grey [
    AMK
    Maz
    Maz's Avatar
    Jan 2005
    East
    1,008
    Do you think it is wise to replace the plugs as well?
    Mineral Grey [
    AMK
    Lewis583's Avatar
    Mar 2010
    870
    Depends on how long they've been in there. I'd take the wet plugs out to clean the oil off them so if they haven't been changed in a while then you might as well tick another job off the list and fit new ones.
    Full VCDS
  1. Replies: 0
    Last Post: 16th June 2009, 07:00
  2. Audi 80 2.0 8V Ignition coil
    By jabins33 in forum Classic Audi Forum
    Last Post: 11th May 2007, 16:10
  3. 3 Ignition Coils gone - Prev. Replaced Jan 2004!!
    By bikefright in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th March 2007, 22:04
  4. PowerCore ignition coil amplifiers VAG 1.8t
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2007, 20:51
  5. All six ignition coils replaced
    By bikefright in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2004, 13:46
