Chris NottSky Insurance
    Aug 2013
    Key doesn't fit door lock
    Hi, I bought an 2001 a3 last month and just changed the batteries in the remote fob, the problem is I only have the one key and after I changed the batteries it's lost it's memory, so I thought ok I will manually unlock the car, well at some point someone has replaced the drivers door and now the key goes in the barrel but won't turn. I am thinking they have forgot to change the barrel when they changed the door. Just need to know what my options are? can I remove the barrel and somehow change the pins to fit my key? Or can I get a barrel to fit my key from anywhere cheaper than audi? Hope this makes sense. Thanks
    Sep 2012
    West midlands
    368
    Quote Originally Posted by Derren2502 View Post
    im in the middle of doing my door lock and basically I removed whole window with runners ect all attached just make sure wiring too window motor all disconnected then undo 4 tourqe bolts2 at sides at top of door and2 at bottom the whole window and frame will slide up and out complete!! Then there's a small gold pin that goes through plastic handle hinges on inside of door handle slide out this with a very very small flat head screwdriver take pictures of how door is adjusted ie where all the adjuster wedges go...
    Then there's a black plate on inside of door on handle itself on inside of door not outside slide this towards wing mirror too release door handle complete there is a plastic lip which holds the rubber seal too stop leaks if this dosent click in properly the lock / handle will leak and cause rain too enter door which will lead too rust good luck! Here's a pick of lock removed and the black plate which actually releases door handle from door!
    Audi s3 8l 2003 silver,brembo brakes,custom front mount intercooler,forged rods,acl race bearings,3inch tip,forge 007p green spring 1 shim,5mm hubcentric spacers,pipewerx 3inch down pipe/200cell race cat,2.75 miltek back non resonated,new piston rings,n249delete,pcv venting too atmosphere,neuspeed quick shifter,uprated clutch/pressure plate...large port agu head,inline fuel pump
    work left/relentless v3 manifold/wmi/blue haldex/antilag/launch controll/custom map!!!!!
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,079
    Chances are it's had a new door or something yea. My passengers door can't be opened with the key for this very reason.
    Also - worth noting that the key fob won't lose it's memory when you change the batteries, something else has gone wrong there.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,988
    they will and do lose memory if not changed in a certain amount of time
    plus you can resync them very easy
    Aug 2013
    Thanks for all your help, I managed to get the barrel out and swap pins around to fit key, couldn't get 3 to fit anywhere so got 5 out of 8 pins back in, reassembled it and the key will lock the door and activate alarm but when I use the key to unlock the door it only unlocks the drivers door and doesn't de activate the alarm. But on the plus side after I refitted everything the remote is now working again. I still want to get this sorted and then get another key made I think.
    May 2012
    RETFORD, NOTTS
    1,716
    Try flipping the batery up the other way, seen a lot of people put them in the wrong way!
    I can get a doorlock to suit your key, pm your details and ill get you a price.
    If you are local and the new lock doesnt fix your issues, I could have a look over the system and see if I can fix it :D
    See my post in group buys and discounts if you need a spare key too :D
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Driver's door lock won't work with key
    By munchkincoupe in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th June 2013, 18:06
  2. Key doesn't unlock all doors or deactivate the alarm
    By billybaggins in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2013, 08:29
  3. Drivers door lock will not unlock with key - HELP
    By graves_x in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2012, 23:39
  4. Does a mk4 golf door lock micro switch fit 8l s3???
    By Audi S3 freak in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2012, 16:38
  5. A4 door locks
    By jodeci in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th March 2004, 20:27
