Chris NottSky Insurance
    Aug 2013
    Norfolk
    67
    a3 tdi 1.9 vac pipes
    I have noticed my vac pipes have started to perish causing leaks, I'm sure I'm gonna seem like a right plonker but can they be replaced with standard silicon vac pipes? and are they the standard 4mm id pipes?
    Mar 2013
    Devon
    613
    Yes silicone is fine. The OEM pipes are 3.5mm and 5mm, but 3mm in place of the 3.5mm will be ok.
    If its a PD engine you will need about 2.5m of the 3mm and 1.5m of the 5mm hose.
    Aug 2013
    Norfolk
    67
    Quote Originally Posted by JimS3 View Post
    How do I tell if its the pd engine? I'm new to the whole diesel thing.
    Mar 2013
    Devon
    613
    Have a look in either the spare wheel well or the first page of the service book, there you will find a data sticker with loads of codes on it.
    Towards the top of the sticker there will be a 3 letter engine code and the power output in KW.
    Engine code may be ASZ, ATD, ALH or similar. Post it up and I can give you more info.
  1. Vac pipe
    By s3 man in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2011, 20:50
  2. brake servo vac pipe question
    By S3 TAM in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2010, 15:37
  3. Quick Q: Common vac pipes to split?
    By Y83OLK in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2010, 13:27
  4. A4 1.9 TDi QS - Split boost pipe
    By Jimmeh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th November 2009, 17:55
  5. Tdi 130 de-cat pipe
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th September 2006, 12:01
