Volks AutosAH Fabrications
Like Tree1Likes
  • 1 Post By fuddyboi
Thread: armrest removal, please help
    Oct 2012
    12
    need to remove my centre arm rest and its stuck solid, have been searching online and found a pdf and they all say undo a m8 allen bolt i think it is, this is connected to a swing arm type section, once removed you pull the arm rest up and its removed however after removing this bolt i get nothing! the armrest wont move etc feels like something more needs removing, not sure if its ever been out before would guess not and so have been a little rough with it incase 13 years of grime is keeping it in place. i only need to remove the armrest not the bracket as i need to remove my centre console for a bit.
    has anyone had this before? really ned to get it out for a while
    thanks
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,076
    once the bolt is in the way the little gate should just swing across and it pops out upwards mate.
    Perhaps try prying the gate with a screw driver or similar?
    Oct 2012
    12
    the gate thing you refer to how far should it move? i have maybe 90 degrees of movement, should there be more?
    Oct 2012
    12
    never mind, we shared a few select words and then it came out ha ha thanks very much
    Sandra likes this.
  1. S4 4.2 V8 Oil Pan Removal - PLEASE HELP!
    By Neil Sowden in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th March 2013, 10:22
  2. Sump Removal ...please help!
    By lucksta in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2009, 12:53
  3. A3 8L Quattro gearbox removal please HELP
    By A3Quattro1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2009, 18:27
  4. A3(8P) armrest fixing - please help!
    By ren in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th December 2006, 17:16
  5. Air Filter Element Removal - Please help
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2006, 21:58
