Sky InsuranceEM Tuning
    Apr 2011
    Dublin, Ireland
    621
    Suspension Bush part numbers
    Ok so my next plan is to replace the suspension. I have ordered koni shocks, h&r springs, a set of s3dave's tie bars & new lcr front top mounts and bearings.
    What I want to do now is replace every other rubber bush on both the front and rear of the car. I know its a bit of an ask, but would someone out there know the part numbers
    Thanks.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    Apr 2011
    Dublin, Ireland
    621
    Thanks.
  1. OEM S3 Engine Dog Bone Bush PART NUMBER PLEASE
    By finesse in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2010, 17:00
  2. S3 / TT suspension part numbers
    By sean_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2010, 08:32
  3. A4 B6 OEM sport suspension part numbers
    By audi130 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th June 2010, 00:04
  4. offside lower suspension arm part number.....please help!!
    By Andy D in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd December 2009, 22:28
  5. rear trailing arm bush part number query
    By s3_kev in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd August 2008, 21:20
