Sky InsuranceBadger5
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    green temperature sender on an apy s3?
    where i think my green cts should be in the plastic housing on the top rad hose i have a white one with a square two pin plug?
    instead of the half circle square plug on my new sender?
    further along i have a blue square four pin plug/sender?
    do i need a different sender im guessing so?
    well i may not need one if the thermostat i fitted today sorts my temp fluctuation, thats a pig of a job with the alternator there lol, to think i read a post on here saying it was easy!
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    Mar 2013
    Devon
    609
    The blue 4 pin sensor is the temperature sensor, but you have bought the wrong one.
    The green one you bought it for the later cars.
    A3-Lee's Avatar
    Dec 2011
    Birmingham
    445
    ^^^ what he said
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    cheers
  1. Temperature sender sensor
    By kashiskash in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th January 2009, 11:58
  2. Dodgy temperature sender?
    By kohoutec in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2007, 15:35
  3. G62 Coolant Temperature Sender - Replacement guide
    By Neil_S in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th December 2007, 20:40
  4. Temperature sender for dash temp gauge
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2006, 19:36
  5. Temperature Sender location & 'limp home mode' ?
    By SimonA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th July 2004, 11:00
