Sky InsuranceEM Tuning
Results 1 to 10 of 10
    Sep 2010
    498
    Need some help. 1.9tdi overheating problem
    Ok, my 2002 1.9tdi was overheating, one of the radiator pipes was hot and the other cold which suggested the thermostat. I had this replaced but it's still overheating, the coolant/want is bubbling and the doesn't seem to be any hot air coming through the vents. Can anyone suggest what the issue could be?
    Sep 2011
    tiverton
    337
    Add egesford on Facebook
    water pump
    Sep 2010
    498
    How can you tell for sure if it is? My friend had a quick look and said there seemed to be water going back into the reservoir.
    Sep 2010
    498
    Are there any guides on replacing the water pump? Is it DIY?
    Jun 2011
    Great Melton Norfolk
    1,340
    Was it an original/genuine Thermostat? Cambelt/tensioner should be replaced if doing water pump as well.
    Sep 2010
    498
    Quote Originally Posted by gen.heinz guderian View Post
    Yes it was an OEM part. The one removed was an Audi one too. It is a difficult task to replace the pump then?
    Sep 2011
    tiverton
    337
    try running it without thermostat, if it still overheats you can rule that out.
    can you smell carbon in your coolant? if so possible HG failure
    temp sensor causes weird problems sometimes- cheap and 2 minute job
    check if rad is flowing- either disconnect top and bottom hoses and put hose pipe in top, or squeeze the top pipe and see if you can feel it in the bottom pipe.
    cambelt/water pump change is only a diy job if youre pretty competent
    Mar 2013
    Devon
    405
    Are you loosing any coolant?
    Sep 2010
    498
    Quote Originally Posted by JimS3 View Post
    Yes as I need to top it up with water or coolant fairly regularly.
    Mar 2013
    Devon
    405
    Head gaskets are common on these, they nearly always go between cylinder 2 or 3 and the adjacent waterway and you therefore rarely get the mayo tell tale signs in the oil. Under heavy load the high cylinder pressure over pressurises the coolant system and pushes it out the tube on the back of the coolant bottle.
    Good diy test for head gasket in these: get car warm one eve (almost up to temp) and then remove coolant reservoir cap to let pressure out. Drive for a bit longer to get fully up to temperature. Then leave the car over night to cool completely. Remove coolant bottle cap and if there is still pressure when its cold it's likely HG failure.
  1. i might have a turbo problem?i need some help
    By 97_A4_1.8Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2008, 14:08
  2. Considering A 1.9TDI - Need Some Help
    By emzino in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th December 2007, 10:27
  3. needs some help
    By HuntsA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st January 2006, 17:00
  4. I need some help on alloys......And lowering.....
    By imported_tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th February 2005, 15:55
  5. Need some help none car related work pranks
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2003, 18:39
