Badger5EM Tuning
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Westy
Thread: Watermeth pump location and height of pump
    Gizmo20VT's Avatar
    Jun 2012
    289
    Hi Peeps
    I would just like to know exactly where a watermeth pump should be installed interms of height vs tank height. I have searched online and see that some setups have the pump higher then the tank itself, others lower then the tank outlet and some just random locations.
    Does distance from the tank to pump effect the setup in anyway?
    Reason for my questions - It would be a first time install and would like to install it correctly first time round
    Gizmo20VT's Avatar
    Jun 2012
    289
    Nvm, I have found my answer.
    Find a suitable location to mount the pump and tank (not supplied). The pump must be located in the same area as the tank and should be mounted at or below the lowest fluid level height.Take note of the direction of flow, indicated by the arrows on the pump body, when mounting the pump. If the tank is mounted in the back of the vehicle the pump should be mounted in the back of the vehicles as well and NOT in the engine bay.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,593
    ^^^ that
    <tuffty/>
    Gizmo20VT's Avatar
    Jun 2012
    289
    ^^^ that
    <tuffty/>
    LoooL
    rear quater panels back off and redo the festo piping.... dam
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,281
    Quote Originally Posted by Gizmo20VT View Post
    LoooL
    This is mine:
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Gizmo20VT's Avatar
    Jun 2012
    289
    Thanks Westy, so no problems with the actual pump rotation being "upside down either"
    Westy's Avatar
    Dec 2008
    17,281
    No mate. I'd copied the setup I'd seen on a few other cars.
    Gizmo20VT likes this.
    S3 Build Thread
    Gizmo20VT's Avatar
    Jun 2012
    289
    Quote Originally Posted by Westy View Post
    Great, thanks alot bud! Much appriciated, will rotate my pump tonight which should then make my piping level with the lowest point on the tank :D!
  1. Fuel pump location/snapped fuel pipe eeekkkk
    By takworldwide in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2010, 07:54
  2. fuel pump location
    By ash3435 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2010, 20:48
  3. Relay (for fuel pump) location?????
    By sam1014 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd February 2010, 08:18
  4. SAI pump location?
    By evilscotsman in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th December 2008, 15:18
  5. A4 2.8Q Oil pump location needed ASAP Please help
    By markcass in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd October 2007, 10:42
