EM TuningSky Insurance
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By beachbuggy
Thread: High pitched noise when on high boost
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    Hi guys, ive noticed i get a noise thats quite high pitched when going above 10-12psi boost and stays all the way up to 18psi. it also seems to be getting worse any ideas got a feeling it might be the turbo car has done 112k
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    beachbuggy's Avatar
    Surrey
    1,746
    failing turbo is a probable cause but ive seen on more than one a boost leak is the issue..
    Paradox1 likes this.
    Nov 2012
    Kent
    459
    is there anyway to test the turbo? will have a look for leaks, how much would a new turbo be roughly?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    Pressure test first of all, and make sure you test it above 12psi!
    TD5 Land Rover Defender build
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Quote Originally Posted by beachbuggy View Post
    X2 most likely boost leak
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Nov 2012
    Kent
    459
    ok, didn't have a chance to look for a leak and then the dv hose popped of the ic pipping 3rd time its happened now because the nipple on the pipe hasn't got the lip? anyway i can make one? also the turbo is still making the noise its like a whining when it spools not the normal spooling noise so my question how difficult is it to rebuild the turbo? and for that matter taking the turbo off?
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    696
    guessing its an s3? if so looking at 4 hours to remove the turbo first time mate, done from above and through the drivers wheel arch with the driveshaft out the way, one of my posts tells exactly how i done it. new turbo is around 600 quid, best off sourcing a reconditioned one but make sure its a genuine ko4 donning the blue tag as theres alot of chinese copys out there that arnt as good quality like mine! assuming it is actually your turbo off course.
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
  1. Strange high pitched noise. HELP
    By Reesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2011, 13:23
  2. high pitch noise when driving? it gets higher pitched with engine revs
    By danonline in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th March 2011, 19:23
  3. High pitched squeal..when turning?
    By GibletsS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2008, 11:39
  4. High pitched noise from rear speakers
    By Jay4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th August 2007, 14:50
  5. High pitched noise when starting from cold
    By ajek in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th November 2004, 15:00
