EM TuningMonster Motorsport
Results 1 to 11 of 11
    Jul 2012
    51
    Unhappy please help p0322 code and no spark
    Hi i bout a very clean audi a3 52 plate 84k as non runner plugged my scanner into it and getting p0322 code and got no spark has anyone come across this and where would the sensor be.thanks
    Jul 2012
    51
    Quote Originally Posted by jay106 View Post
    auq engine code
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    16706/P0322/000802 - Ross-Tech Wiki
    16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
    Possible Symptoms
    Engine shuts off
    Engine doesn't start
    Speedometer inoperative
    Glow Plug Indicator Lamp (K29) flashes
    Possible Causes
    Engine Speed Sensor (G28) loose
    Engine Speed Sensor (G28) faulty
    Possible Solutions
    Check Engine Speed Sensor (G28)
    Special Notes
    The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position.
    Other words... crank sensor...
    <tuffty/>
    Jul 2012
    51
    ok thanks would this stop it sparking it was running then went to start it and it wouldn't fire no spark
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Yes... if the crank sensor isn't working then the ecu won't even now went to spark....
    <tuffty/>
    Jul 2012
    51
    ok thanks how much are they about? and where is it on the engine thanks for your help
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,630
    Over £100. I got mine for £80ish though after abit of haggling at Tps (can tell I'm asain, almost as bad as joe ). Bit of a bugger to get out but Harlem shake that thing out.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,316
    you sure they're that much Gops?
    I paid £23 at GSF for one when mine went, 15 minute job to swap it over
    Jul 2012
    51
    right a trip to euro car parts and £13 later all up on the button so happy days but stil got water going into oil oil cooler ok so thinking head gasket
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,630
    Yeah I went to Tps didn't I! I'm sure it was that that cost me that much.. Got the receipt somewhere..
  1. Help Please: Abs Ecu Coding and help with ecu.
    By asasprey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2011, 18:02
  2. arghhh please help, fault codes keep increasing
    By brys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2010, 21:37
  3. Please help Miss Hull and District
    By MikeSel^ in forum General Chat
    Last Post: 17th April 2009, 05:41
  4. Please help with codes..airbag.
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th July 2008, 02:01
