Chris NottEM Tuning
    Jan 2012
    Tamworth
    59
    Hunting/Erractic revs/misfire
    Hi all,
    been out to get some fuel just, and i put my heating on in my car for the first time, since the start of the summer and noticed the car misfiring. So i pulled over to car was revving/hunting on its own. The needle would sit at 1000 revs then drop to about 600 then back to 1000. Any ideas. Surely the heating being on cant be linked to this, can it?
    Thanks for reading
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Vacuum leaks sounds like... by heating you mean you have turned the heat up or actually switched aircon on? could be just that the extra load of the compressor is highlighting this now...
    <tuffty/>
    Jan 2012
    Tamworth
    59
    My aircon doesnt work chap, condensor is knackered. I mean i put the heater on to de mist my windscreen.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,550
    Still say vac leak but I would scan for fault codes as a start and look for split pipes..
    <tuffty/>
    Jan 2012
    Tamworth
    59
    Sound, thanks, vacuum pipes are on my list to sort out, along with boost pipes.
  1. Long time to start - hunting with misfire
    By salad.dodger in forum General Technical / How To
    Last Post: 18th June 2011, 12:45
  2. Not holding boost & Rev hunting..
    By Shy19s in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2009, 21:26
  3. Rev hunting
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2009, 22:27
  4. MY AUDI A3 2.O TDI IS SPLUTTERING/MISFIRING ?? BETWEEN 2 & 3 THOU REVS
    By lee16037 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th August 2009, 10:32
  5. Misfire in 130 PD a4 at 1500-1800 revs
    By technics100 in forum Diesel forum
    Last Post: 15th December 2007, 21:00
