Results 1 to 10 of 10
    Nr. Guildford
    133
    A few 8L issues and questions, help welcome!
    Hi all,
    I'm a fairly new 8L owner, had it a couple of weeks and I have a few issues/questions if anyone is willing to help!
    1) The car has a rattle/knocking through the bulkhead at idle and low speeds, it goes away at speed and if you rev the engine slightly. It can't really be heard from outside the car as the noise seems to transfer through the car.
    2) The stereo has a high pitched squeak from the rear, its the amplified system but not Bose. The headunit is aftermarket. It isn't particularly loud but you can tell its there!
    3) Has anyone fitted an interior light from an A4 B5 like this one? It looks the same as the one I have but with the little red leds: 2000 AUDI A4 B5 AVANT ESTATE 2.4 V6 BREAKING INTERIOR LIGHT PANEL ONLY | eBay
    Thanks in advance!
    2001 A3 Sport TDi 130 (ASZ)
    Milltek System & Downpipe
    'BlackSmoke' Remap
    Darkside EGR Blank
    CG Motorsport Dual Friction Clutch
    18" RS4 Replica's
    H&R Monotube Coilovers
    Mar 2013
    31
    1 & 3 not sure but point 2 can be a common problem with aftermarket headunits and amplified rears. You could try a different wiring harness but you may find you have other niggles such as popping when changing source etc
    Only way for perfection is to re-wire rear set-up!
    Nr. Guildford
    133
    It pops when it turns on too, to be honest I thought this may be the case and really want a factory CD headunit and USB input! Just need to find one that is in good condition and a suitable input adapter.
    Thanks!
    'BlackSmoke' Remap
    Darkside EGR Blank
    18" RS4 Replica's
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    1) Dogbone mount might be duff. If so, get a red diesel or yellow powerflex one. Do you get wheel hop if you accelerate quickly?
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Nr. Guildford
    133
    I did have a look at the dog-bone, looked ok but access wasn't great. It seems like there is too much movement or the mounts are all sagging so things are fouling, or something is falling off!
    'BlackSmoke' Remap
    Darkside EGR Blank
    18" RS4 Replica's
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    Nr. Guildford
    133
    I'm a bit OCD and would really like a factory light if possible!
    'BlackSmoke' Remap
    Darkside EGR Blank
    18" RS4 Replica's
    Nr. Guildford
    133
    Dogbone changed, still the same. Have been advised its my DMF? Sound likely?
    'BlackSmoke' Remap
    Darkside EGR Blank
    18" RS4 Replica's
    Big Al's Avatar
    Engine knackered!!
    May 2011
    West Midlands
    295
    Quote Originally Posted by Max M4X WW View Post
    Yes, change the clutch too. Stick the car on a ramp, rev the engine whilst stationary to check for vibration. Any decent VAG tuner/garage should be able to diagnose & help.
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    Nr. Guildford
    133
    I trust the guy who's looked at it, I'm just a bit annoyed with myself as it was fine two weeks ago when I bought it. Seems pointless to put a standard kit on too which is £330 when I can get an uprated one for £575. (Prices from Darkside Developments)
    'BlackSmoke' Remap
    Darkside EGR Blank
    18" RS4 Replica's
  1. DIS and HID Questions. Help Please. :)
    By PhilW in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th July 2012, 22:39
  2. Few things I need your help and advice on.
    By supanova in forum The Project Room
    Last Post: 19th May 2011, 00:06
  3. N249 bypass.. questions about N112 and SAI, help please (welly lol)
    By coyle in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2011, 00:05
  4. Just bought an A3 and have a few issues - can u help??
    By jrsteeve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th August 2008, 19:56
  5. A few Questions - HELP needed
    By cbass in forum General Technical / How To
    Last Post: 28th June 2004, 22:32
