Sky InsuranceChris Nott
    kkk
    Aug 2013
    North London
    109
    Help with maf sensor pls
    need help before i waste any money, got fault code P0102 mass air flow sensor signal too low.
    i checked the pins with a multi meter and only got 4.9v on one of the pins but no 12v or any thing on any of the others.
    i then checked with vcds and its showing no reading on the maf block 003, what could be wring? i did notice that one of the pins in the connecter block is loose think it might be the ground could this be the problom?
    thanks guys
    Neil
    kkk
    Aug 2013
    North London
    109
    oops, i get 14 volts and 5 v with the engine running and the plug disconnected so is this purely just a dead maf?
    thanks
    www.badger5.co.uk
    May 2004
    nr Glos
    6,938
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    kkk
    Aug 2013
    North London
    109
    bill your a star mate, will come in handy for future ref.
    i think its fixed on this one aswell, i bought a cheapo gsf 30 quid maf and instantly no fault codes and reading 4.3g/s at cold idle does this sound about right?
    just got o hope it doesnt break down higher up the revs when i can get to drive it
    thannks
    Neil
    www.badger5.co.uk
    May 2004
    nr Glos
    6,938
    personally i only use bosch maf's not pattern copy ones...
    sounds like it was the culprit tho
    bill@badger5.co.uk
    kkk
    Aug 2013
    North London
    109
    yea im the same but in this case not knowing if its at fault i took the cheap option, but if it goes in a few months il have no problem with putting a bosh one in, might just do it when i get paid if its fixed the running issues, then keep this as spare.
    thanks for that info bill
    Neil
  1. Help with MAF problem please??
    By sherry in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 10th September 2012, 07:16
  2. Help with parking sensors ?
    By Lings in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th June 2011, 16:18
  3. Help with longitudinal sensor
    By cawood in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2010, 23:10
  4. Help with Lambda sensor
    By teambeer in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th November 2010, 14:30
  5. possible maf sensor fault........ pls help
    By lazzaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th January 2006, 09:24
