AH FabricationsChris Nott
Results 1 to 14 of 14
    audiholic ste's Avatar
    Aug 2013
    163
    broken rear spring
    Today the bounced the car up the pavement and broke the rear drivers side spring . Audi s3 8l 2000 . My question is do I have to buy a full set or can I just buy the rears and what spring should I go for apex hr ? The car has in my opinion always been stiff and I've felt every little bump in the road
    Nov 2011
    devon
    86
    If your going to upgrade you will need full set but if genuine ones just get rear pair
    Aug 2013
    163
    Bit of a mistake should have said . Today the wife bounced ....
    Nov 2011
    devon
    86
    i got genuine ones off a breaker with 60k on it for 30 delivered , there are different coloured spots for different spring lvngths so make sure u gvt thv right ones .
    Aug 2013
    163
    The springs are rusty as hell . Don't think I'll find any coloured spots on them or do u mean on the new springs if I go to a breaker ?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,836
    Buy new mate, used ones will go the same way, it's a known fault. I'd be going for fresh shocks too whilst its all off.
    You've got to have a laugh!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,836
    Might aswell have at my thread below for some info.
    Audi S3:Eibach vs H&R vs Apex lowering springs.
    shady-ninja's Avatar
    843
    on a car that old I will change all the shocks along with the springs possibly with an uprated one.
    if its a basic 1.6 A3 then I will just change one spring.
    don't cut corners or else it might bit back in unfavourable conditions such as the wet.
    Aug 2013
    163
    What's a good spring and shock combo . Don't want it stiff as hell and end up with a sore back . My back is bad enough through work .
    Aug 2013
    163
    Being a numb nut when it comes to cars what's the difference between springs and shocks and coilovers .
    Aug 2011
    Plymouth
    604
    Add Lavis89 on Facebook
    Springs are springs, they bounce the wheels back into place, shocks are the shock absorbers, they help dampen the bumps (Shock absorber - Wikipedia, the free encyclopedia), coilovers are springs/shocks in a single unit and adjustable so you can choose your ride height and usually give adjustable dampening aswell (Coilover - Wikipedia, the free encyclopedia) with all above it's very much a matter of you get what you pay for.
    2001 1.8T Quattro Sport 89k covered ARY engine.
    Remapped at Badger 5, 213bhp - 235lb/ft torque.
    HS2K cone, FMDV008, Silicon TIP, 18" RS4 (reps), AP coilovers, Catch can, n249 bypass, Toyosport 3" Downpipe/Decat, S3 Front brakes, Polyflexed Dogbone, S3dave adjustable tie bars
    Soon to be done: SAI delete, Install the toyosport FMIC i have kicking about in my living room
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    564
    Bilstein's & Eibach Springs are decent enough. 20mm drop over standard, so not too bad.Springs & shocks are just that.Coilovers have the spring over the shock & are fitted as a single unit.Never used them as from what I've read they are generally hard as hell.
    ...... Waiting Paitently...
    Aug 2013
    163
    New springs and shocks then .
    Aug 2011
    Plymouth
    604
    i have coilovers on my car (the entry model AP coilovers) and i find them to be better all around than what the car had on as standard, but the standard suspension was 12 years old.
  1. S3 BROKEN REAR SPRING
    By speedy lynn in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2011, 12:47
  2. S3 BROKEN REAR SPRING
    Last Post: 14th February 2011, 18:50
  3. REPLACE OEM SUSPENSION AFTER BROKEN REAR SPRING
    By Blounter in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2011, 08:19
  4. Another broken rear spring.....and strange tyre wear.
    By hooley in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2009, 11:43
  5. Failed MOT, broken rear spring
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th November 2008, 08:59
