Results 1 to 10 of 10
    Sep 2013
    6
    Antenna amplifier location
    Please can anyone tell me exactly where the antenna aerial amplifier is located within the car (A3, 2002 reg, post face lift, 1.8)?
    I'm pretty sure it's part # 4D0035530C.
    My radio signal has gone completely and I'm going to try to replace this part to get the signal back...
    mattyboy199's Avatar
    Nov 2005
    UK
    1,679
    If its not built into the based on the roof (which is where it comes from factory) it will be located under the base inside the car (this was a newer design)
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Sep 2013
    6
    Thanks mattyboy,
    Just to make sure I understand right, you're saying that it should either be...
    - within the roof
    or
    - under the bass box in the boot
    - is that right?
    I've had some of the roof trim off today near the aerial and can't see it. Do you know exactly where it should be in the roof??
    appreciate your help...it's this part...
    AUDI S3 A3 8L Aerial Antenna Amplifier Control Diversity Module 01-03 4D0035530C | eBay
    Sep 2013
    6
    Thanks Matty,
    Just to check I understand right...you're saying that it should either be in the roof or under the bass box in the boot?
    I've had some trim off the roof around the aerial today and couldn't see it - where exactly in the roof should it be?
    cheers
    Nov 2005
    UK
    1,679
    Quote Originally Posted by A3 Driver View Post
    Thanks Matty,
    cheers
    No the base of the aerial (cone shaped) on the roof (externally) is the amplifier it will be solid. If not then the amplifier will located inside the roof beneath the base. If you have rear interior lights pull the unit out & have look.
    wanted for 8L S3:
    Milltek system
    vrbob's Avatar
    Jun 2007
    Southampton
    2,290
    the FM boosters are in the trim around the inside of the rear screen as they use the heated rear screen element to get more signal
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    russwuss's Avatar
    Feb 2013
    370
    Have you recently changed the stereo? Some built in Audi stereos have a amplifier, if you have a aftermarket one it won't have this amplifier.
    Sep 2013
    6
    A quick update...
    It's a bee-sting screw-in aerial base - so the amplifier isn't externally within the base
    I've had the internal rear passenger light out and it's not internally beneath the aerial base
    I've pulled down the plastic trim that surrounds the top of the rear window internally - not there either.
    The only trim parts I haven't taken off are the plastic trims to the left and right of the rear window, that also go towards the rear passenger doors...
    It's a factory standard audi chorus radio/cassette...no AM signal at all, FM signal only in high signal strength areas - then it crackles into nothing as I drive away from the area...
    Thanks for all your advice so far...keep it coming!
    Jul 2013
    27
    Hi Mate,
    I have the same problem, if you find out how to replace, could you let me know.
    I've been searching internet looking for a video of how to replace aerial base, but so far no joy!
    Sep 2013
    6
    ...Audi just quoted £91 + VAT an hour to diagnose the problem. They said if it didn't take an hour, £ would be deducted according to how long it did take. They'd then provide a full quote for what needs to be done and how much it would be to fix. hmmm...Probably looking at around £250 maybe for Audi to fix...
  1. Best location for new amplifiers in B7 Avant?
    By Nufab in forum In-Car Entertainment
    Last Post: 19th June 2013, 21:49
  2. a3 2004 fsi amplifier location
    By djlazerblue in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th June 2012, 11:38
  3. Location of org.amplifier (S3) ?
    By Dreminator in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2010, 23:44
  4. FM Amplifier location
    By Toxic in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2009, 23:16
  5. radio amplifier? microphone location?
    By fenian672000 in forum In-Car Entertainment
    Last Post: 10th December 2006, 23:54
