Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By superkarl
Thread: LargePort Head... whats needed for safe 450hp max...
    limbo118118's Avatar
    LORD
    Oct 2009
    Wrexham.. North Wales
    354
    Add limbo118118 on Facebook
    on a LP head, (AGU) whats needed to make it safe at running around 450bhp max.
    ino of :-
    - exhaust vavles
    -guides
    -stem seals
    but what else? anythin needed ? or other things just for performance etc?
    any help would be appreciated ( i have been researching this on google for ages and carnt find any relevant answers!)
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,456
    You have hit the nail on the head, Port it will help also
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,469
    For 450hp you would be looking at supertech valves and springs... single groove ones...
    Guides (normally exhaust guides as they wear) and stem seals are a given...
    Can't have been googling that hard as all the info is on here
    <tuffty/>
    LORD
    Oct 2009
    354
    Yeh I was hoping to be sending it over to you andy once iv bought the parts! . An tuffty I have been searchin just hard to pin point what I was after. Iv already got ferrera exhaust valves here. So could I get the supertech intake vavles/springs an thed run fine together I presume?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    To add, its not really power that dictates valvetrain but where the power is in the rev range.
    If its a big turbo with large housing then power is goimg to be later and you will want to rev more for a decent power band.
    Thats when the stock stuff is inadequate.
    Good vid on youtube of a bench test of stock valvetrain and they reckon they had valve float at 7500 (bench test tho so not quite real world conditions) so thats when you'd benefit from Ti springs and retainers, and inconel exh valves to better deal with heat, and single groove for security.
    The video is also accompanied by an uprated test, all supertech i think, that was taken to 9k without float, although it was a little unfair as they use solid lifters, which 99% of people wont run, or need to run.
    Build the head around the other hardware, predict what you need to rev to.
    Unless youre made of money just do the whole lot and rest assured its bombproof
    Gizmo20VT likes this.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,469
    Quote Originally Posted by limbo118118 View Post
    Exhaust valves on their own are just a marginal upgrade to the whole valvetrain... as superkarl has mentioned its revs thats the issue... to get 450hp from a 20v normally means biggish turbo and with a biggish turbo comes later spool narrowing the power band... more revs will increase that power band and bigger turbos will still provide flow at those higher revs... a decent setup will make power at as many revs you can throw at it (Bill's Ibiza revs to 8.5k on hydro's with no power drop off)..
    Most valve train failures are from worn guides and the valve not seating right at high revs... strains the valve and it breaks... OE exhaust valves are sodioum filled so pretty good to start with but std springs will be an issue...
    For the road you want to be aiming at 7.5k to 8k tops... my rev limit is set at 7.8k currently...
    As karl mentioned above you need to build around the spec you are going for and the spec can be determined by what you want from the hardware... have seen too many cases of throwing parts at a car and non of them working properly together as the spec is just wrong... start with intended use and power goals... its easier to spec from that and determine what other hardware you need to support it...
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,141
    got a link to the uprated valvetrain video karlos?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    LORD
    Oct 2009
    354
    Thanks alot for your help fellas feel ive learnt alot just reading these few posts! So with me already having the sss ferrera exht vavles. Its worth my investment to get the supertech spring/titanium retainer set aswel as supertech intake vavles. Then possibly a port and polish from andy an il be safe! any idea what I could safely rev to with this setup? Cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,469
    Supertech retainers are designed for the supertech single collet valves... better off selling the ferrera valves and buying a complete set of supertech valves/springs tbh..
    With that you can rev to around 8k (8.5k at a push with thicker oil) on hydro followers and 9k with solid... for fast road/occasional track then stick to hydros
    <tuffty/>
    LORD
    Oct 2009
    354
    Hmm il have to have a think then with my choices! Is there any where in the uk that sell supertech setups? Just getting them from the states I hate all the hidden charges :s
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,469
    Bill sells them...
    <tuffty/>
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Id speak to some of the big US retailers about what springs + retainers to use with the ferrea stuff IF its a hassle to get rid and change etc.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,469
    Ferrera do their own but not cheap... you could also use Cat Cam springs... just need to make sure they are compatible with std three groove valves...
    <tuffty/>
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    I went for the complete Ferrea kit, not cheap mind you.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    LORD
    Oct 2009
    354
    Think il work out better to sell the ferrera which shouldnt be hard as there brand new in packaging an then speak to bill about ordering the supertech setup
  1. Whats needed for Shark Stage 3
    By ilim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2012, 23:26
  2. whats needed for my build plan!?
    By limbo118118 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2012, 22:35
  3. whats needed for 250bhp
    By jamie226bhp in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th September 2009, 10:19
  4. What parts do I need for a service
    By johnlondonw3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th January 2007, 10:09
  5. what bulbs do i need for s3 fog lamps?
    By edward_harris in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2007, 23:27
