Results 1 to 21 of 21
    Jul 2013
    Sussex
    40
    Is my cam chain stretched?
    Hi the cam mark on the pulley is lined up with mark on head
    Jun 2013
    Sheffield
    76
    I'm pretty sure that the 8L doesn't have a cam chain
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,044
    Quote Originally Posted by LynxE View Post
    Yes it does... cam belt from crank to exhaust cam and cam to cam is a chain..
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,044
    Quote Originally Posted by S3ben View Post
    Not sure what you are asking dude... pics are a little dark to see properly...
    Are you on about the timing marks on the cams etc?
    <tuffty/>
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,468
    Looks to me like the exhaust cam is out. If the pulley is in time that would suggest the cam sprocket isnt pressed on right.
    A stretched chain will only get taken up by the tensioner, so no effects as long as its timed correctly.
    Jun 2013
    Sheffield
    76
    <tuffty/>
    Ah OK
    Well I'm a newbie at all this. I just thought some cars had a belt and some had a chain. Didn't realise that some can be mixed
    So does this chain need to be replaced like the belt does? I'm guessing all chains should (probably not always like in the S4) last the life of the car?
    Jul 2013
    Sussex
    40
    Hi sorry for vague description ill get some better pics up tomorrow. I've taken the car to have the cambelt done twice now and it always comes back a tooth out. So I got fed up with garages and had a go myself not the first cambelt I've done. But this one seems a pain. Lol I line all timing marks up cam and flywheel. But when I go to put belt on to crank sprocket I have a sprocket tooth inline with the cambelt tooth??? Just thinking cam chain stretch could be the answer. I'm stripping it down on sat so ill take pics and
    Jul 2013
    Sussex
    40
    Just want to have fun I my s3 and this is stopping it all
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,044
    Its dead easy for it to be a tooth out... you have to double check before pulling the pin...
    At TDC the exhaust cam mark needs to line up as per my pic above...
    The chains are pretty resilient and generally don't stretch to the extent that they throw a correlation fault code...
    There is no need to touch the cam chain when doing a cam belt
    <tuffty/>
    Jul 2013
    Sussex
    40
    Thanks for the advice all taken on board. Is the exhaust cam notch suppose to be in line with the arrow? Or slightly to the right of it?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,044
    In line... the inlet cam will vary depending on how compressed the cam chain tensioner is...
    Have you removed the cam chain?
    <tuffty/>
    Jul 2013
    Sussex
    40
    No I haven't dont know if someone in the past has?
    Jul 2013
    Sussex
    40
    It dose have a pattern part (china made) can sensor could this be a problem as not the best quality part? Just a though
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,044
    What fault codes you getting?
    <tuffty/>
    Jul 2013
    Sussex
    40
    When it's a tooth out towards intake mani I get incorrect correlation cam crank g40 g28. When a tooth out towards bulk head I get cam sensor short to ground. I also get epc light k132 malfunction. If I clear the epc it will stay off for 2-3 days?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    short to ground is'nt liklely a position error tho is it?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Jul 2013
    Sussex
    40
    I've checked voltage and ground on cam sensor ill pull ecu and check switch wire to ecu. It's just that its a tooth out but code changes when out either way. Is this possible??? Cam mark and flywheel marks don't line up
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,044
    I'd check your cam to cam timing...
    I have seen the short to ground thing before and pretty sure its due to cam to cam timing being out...
    <tuffty/>
    www.badger5.co.uk
    May 2004
    nr Glos
    6,952
    actually scratch what I said... tuffty/marks reminded me of a car we had in which had this very codem which made no sense relative to the cause, which was cam to cam timing being wrong.
    bill@badger5.co.uk
    Jul 2013
    Sussex
    40
    Thanks to you both ill strip it down tomorrow and check it out. Ill post pics if anyone could verify anything out of place. Once again thanks for all the help on this.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,071
    Mine threw the short to ground code when the Cam Belt was out, but not a tooth about 6..
  1. 3.2 cam chain stretch.
    By paddy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th June 2010, 22:09
  2. Stretched Cam chain / faulty intake camshaft adjuster solenoid
    By itssam in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th September 2009, 11:40
  3. cam chain tensioner replacement
    By brendan in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st June 2008, 16:18
  4. Cam chain failiure
    By Broken Byzan in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th September 2007, 23:41
  5. Cam Chain and Tensioner
    By taj in forum TT/TT-S/TT-RS Forum
    Last Post: 25th August 2004, 18:23
