Volks AutosAH Fabrications
Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By Imola
Thread: Help with first set of tests please - DATA now added
    Nov 2004
    39
    Hi
    With regard to my ongoing issue I posted here, I have purchased a Ross Tech licence for VCDS-Lite and it finally arrived today (annoyingly it took too long to arrive and I was off work yesterday and Monday hoping to use it!!+)
    Now I have it, when I get home tonight, how should I use it to check my MAF values, N75, boost etc.? Do i leave the car stationary and log? Do I run it on the road? Do I need to boot it in a gear form x revs to y revs?
    I also am starting to think my DV is problematic - is there any way to identify this from the logs?
    Any help much appreciated as this is my first time with anything like this
    thanks
    Nov 2004
    39
    thought i might have a bit better response
    epox's Avatar
    Oct 2012
    Glasgow
    483
    try the vcds forum on the site, hope u get some help soon
    mark
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Assuming you haven't read this thread then...
    IMPORTANT! - When posting asking for help... - PLEASE READ BEFORE POSTING (UPDATED)
    Info on blocks and what they mean can be obtained in the thread for further reading... also includes an brief explanation of how to do a log run
    Without know hat you think the issue is its difficult to advise what blocks are best to log first...
    Always start with a fault code scan...
    Why do you think your DV is problematic? they pretty much do one job...
    A list of fault codes (which again can be looked up using links to Ross Techs wiki in the thread above) would be a start and an explanation of what symptoms you are experiencing
    <tuffty/>
    Nov 2004
    39
    Thanks Tuffty
    The DV didn't hold pressure very well when I covered the vac hole after pushing up the piston - it turns out it is a fake Chinese rip off of a Forge, sold to me as a Forge 7 years ago
    The car surges on gentle throttle openings in 3rd 4th around 3000-4000 - it also lags for a couple of seconds when I open the throttle on the motorway at normal speeds whereas it used to just pick up and go almost immediately
    I am also trying to establish the cause of my low end torque loss. I have a new VAG supplied MAF that reads 3-4g/s on tickover and 50 or so g/s max flow on vcds. I think I should be seeing more like 200+ g/s on a tuned S3?
    russwuss's Avatar
    Feb 2013
    368
    Quote Originally Posted by Imola View Post
    Thanks Tuffty
    When you say max flow, are you actually talking the car out and giving it the beans to log MAF values? You're right though it should be near 200g.
    I had the same thing on my car when I first brought it - turned out to be a faulty N75 (less than 40 off eBay for genuine one) also replaced the DV for genuine one and been perfect ever since. Definitely worth doing imo...
    Don't bother replacing DV with forge.. Stock one works perfectly :-)
    Any fault codes?
    Nov 2004
    39
    Thanks Russ - I have been hesitating over N75 as unsure what it would do. Will be ordering today (I already have the £40 in my watch list
    Nov 2004
    39
    Hi all
    Could you look at the following and comment on my ongoing issues please - the problems are well documented in other threads.
    This test was a run from stationary to 100mph flooring it in each gear as I wasn't sure what would be the best test. The MAF appears low to me
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Dude... did you read the stuff in the link I gave you?
    Run should be done in third gear, start at 2000rpm and accelerate foot to the floor until redline or as close to redline as is legal and safe...
    You say your issues are documented else where but with out this info in this thread there is no context... no one is going to hunt around and look for your threads dude... post the issues here and we can go from there...
    Bin the chinese DV... it leaks... Forge ones leak so this will be worse... bang an OE DV on, clear the fault codes and report back on any that come back... if you know something is not working then replace it... all you are doing is skewing the results of any diagnosis...
    What year/engine code S3 do you have? makes a difference to suggesting blocks to check... as does knowing what you think the symptoms are
    <tuffty/>
    Nov 2004
    39
    Sorry Tuffty, the run was last night around 5.00pm, before i saw your post and link
    Will do the run as you suggested this evening after work
    The car was registered 1st Jan 2003 and is a BAM
    Sorry about not putting the details in - I thought people might not like me reiterating the same info.
    Problem was as follows:
    There has been a nice torque spike around 2500 since AMD chipped 7 years ago. This had gone.
    It also sort of hesitated/jerked/surged (hard to explain) between 3000-4000 when accelerating on a partial throttle when joining a motorway etc..
    Disconnecting the MAF made it much more like before as far as the torque spike was concerned, and helped smooth that surge/hesitation thing too.
    So, we replaced the MAF with a new VAG unit. It didn't cure it, but it feels better most of the time.
    Now, when I am sitting on motorway at, say 70 (with new MAF on), and decide to 'squirt' it by the car in front, I need to press the pedal much further (like on a normally aspirated car) and there is often a big lag before it goes. It used to require the smallest of presses on the pedal and shot off.
    To explain the torque spike I refer to. After reamp, +DV, + Milltek the car pulled hard at 2500rpm easily leaving traffic behind (very flat delivery until 3500 before the remap etc.). Around 3500ish it then pulled really hard and 4500ish it was warp speed until near the red line.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Okies...
    Bin the DV and fit an OE valve...
    Clear fault codes and run the car awhile to let stuff settle then rescan and post any that return... do not clear the codes... with the engine warmed and idling, check block 032 and see what fuel trims are doing...
    Log block 003, 020, 118 initially as directed... engine needs to be at operating temp...
    Only post the run data... (remove all the chaff around it but leave the headings obviously... )
    <tuffty/>
    Nov 2004
    39
    Hi
    Ran the tests tonight. Seemed to go well, but lacked the torque at 2500. Still has old DV on though as I ordered a new Forge when we realised mine was a fake and still waiting for the genuine Forge (didn't realise they were not as good as oem ).
    Couple of runs - block 020 only gave me four boxes with 0 in and CF at the top, so not included here
    Run 1
    Run 2
    Block 32 at tickover before the test runs
    Block 32 at tickover after the test runs
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Adding fuel on idle... looks like you have a vacuum leak and the n75 looks flat out... IAT's look high (guessing you are on std SMIC's)..
    Plus side, 0 CF's means no timing pull...
    Now try blocks 002, 031 and 115...
    <tuffty/>
    Nov 2004
    39
    Forgot to say - no fault codes at the minute
    Standard intercoolers
    Nov 2004
    39
    Hi
    This is this morning's run - still has Chinese DV. Much cooler this morning with light rain, so it felt stronger and more like before - not as it was though
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Hummm... looks like your turbo is tired or you have a leak somewhere... actual boost is struggling to meet request and based on your 118 log previously the N75 is flat out..
    Smoke test next... (and change the DV)
    <tuffty/>
    Nov 2004
    39
    Hi Tufty
    Not had a chance to find a place to get a smoke test yet, but the car was very much better after fitting the new DV and checking all the pipe clamps (replaced some that didn't seem really secured). Nice torque surge again and increased power.
    I had also ordered a replacement N75 and that was the icing on the cake Suddenly the car stopped hesitating around 3000-4000 and instead simply takes off at 3500 like it did 7 years ago (but probably even more strongly now) when first chipped. I think over time it has probably been slowly losing that sudden urge and as it was a slow decline (and the car was still fast), i didn't notice it until it came back. Feels like a motorbike powerband now
    Thanks for the help, i literally could not have done this without the forums help
    <tuffty/> likes this.
    Nov 2004
    39
    MAF is now 208g/s which with the /0.8 calc works out around 260bhp
    I think this sounds reasonable for a stage 1 tune with milltek and Forge that's done 97,000 miles now (77,000 of them chipped and milltek ) All else standard on engine side
    I would like it nearer 300hp of course..............
  1. need help with a few small problems please :)
    By sam1014 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2010, 19:58
  2. Help with my A3 1.8t please
    By Jay-a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2010, 18:27
  3. help with rear main oil seal please
    By PARKER in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th July 2009, 13:00
  4. Help With Delayed Lease A3 Sportback Please
    By smiffy123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2008, 13:20
  5. HELP WITH THIS ...TAKE A LOOK.....PLEASE!!!!
    By vw754 in forum Diesel forum
    Last Post: 1st March 2007, 23:50
