AH FabricationsEM Tuning
    Aug 2013
    37
    Fuel filter location a3 1.8t
    Howdy all,
    just wanted to know were the fuel filter location is on my 1.8t a3 also is it easy to replace at home?
    thanks
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    Should be under the rear of the car on the drivers side. Easy to replace, 5 minute job. Jut press the buttons in to release, watch the bit of fuel that drops out, clip the new one in the right way round, job done!
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Drivers side, underneath the car just forward of rear suspension arm between the fuel tank and the sill... easy enough to do but the clips can be a bugger... do NOT just wrench them off... there is a built in release clip you need to push in then wriggle the fitting off the end of the filter..
    <tuffty/>
    Vex182's Avatar
    Apr 2012
    Hinckley
    879
    Exactly as above Love the pic.
  1. A4 B7 2.0 tfsi Avant quattro Fuel Filter location?
    By gixer in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th January 2012, 22:51
  2. Fuel filter location?
    By ButcherV6 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th September 2010, 06:32
  3. Fuel filter location ?
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th April 2010, 09:35
  4. 2.8 v6 fuel filter location + which air filter
    By audi1664 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2010, 21:50
  5. fuel filter location
    By S3 chj in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2009, 09:38
