Sadly that will only do ECU related codes and not others modules in the car... as said though check the connections... other thing to check is the wires going up to the seat side airbag... they have a habit of fraying on two door cars from the seat back being moved to let peeps in the back...
All connectors checked and fine. Wiped code at garage and all Ok. Why do they store one off faults. I had clio and Airbag light everything I moved seats but would go away after turning key.
