i have a problom with my clutch and would like to know if anyone has come across this before and weather there is an easy fix for it?
when the car is cold there is no pressure at all in the clutch pedel untill its below the pivot point but then has pressure and clucth works as it should, but is starting to be hard into gear as it gets abit worse.
but when i use the clutch for half hour to 45 it seems to magicly come back and be faultless, untill i dont use it again for a while, be that driveing up the motorway or parking up, but is lower after parking up.
i understand mine has the hydrolic release bearing, could it be air in the system? could it be connected to my abs pump issue?
or could it just be on its way out?
im struggling because it seems to come back and be great whilst im useing it.
dont fancy pulling the box to find it just needs bleeding :/ whats the process for bleading with a hydrolic release bearing?
thanks guys youve been a great help so far
Neil
Neil
