Sky InsuranceEM Tuning
Results 1 to 36 of 36
Like Tree2Likes
  • 1 Post By kkk
  • 1 Post By kkk
Thread: A3 quattro 5 spd clutch issue!
    kkk
    Aug 2013
    North London
    109
    i have a problom with my clutch and would like to know if anyone has come across this before and weather there is an easy fix for it?
    when the car is cold there is no pressure at all in the clutch pedel untill its below the pivot point but then has pressure and clucth works as it should, but is starting to be hard into gear as it gets abit worse.
    but when i use the clutch for half hour to 45 it seems to magicly come back and be faultless, untill i dont use it again for a while, be that driveing up the motorway or parking up, but is lower after parking up.
    i understand mine has the hydrolic release bearing, could it be air in the system? could it be connected to my abs pump issue?
    or could it just be on its way out?
    im struggling because it seems to come back and be great whilst im useing it.
    dont fancy pulling the box to find it just needs bleeding :/ whats the process for bleading with a hydrolic release bearing?
    thanks guys youve been a great help so far
    Neil
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    if it needs bleeding there must be a problem with it to be letting the air in there in the first place, im not familiar with the clutch assembly on these yet, have you checked for any visual signs of a leak?
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    kkk
    Aug 2013
    North London
    109
    yea but was like it when i got it so may just not been bled properly as clutch feels good so could be new:/
    no leaks except rocker gasket slightly, never a drip anywhere
    kkk
    Aug 2013
    North London
    109
    and id expect a leak if it was slowing coming back to life but example when it came back after a 90 mile drive i was going into a big round about quite quick and change down to third and it felt fine from there lol, till i started stopping off places and driveing back home
    kkk
    Aug 2013
    North London
    109
    WoW, no one knows anything really???
    I read last night this is the best forum for the 8L chassis and possibly the best for the 1.8T engine??? Hmmm.
    Lewis583's Avatar
    Mar 2010
    870
    Neil, relax mate. People do have a life outside of the internet and as such may not always be able to answer pronto.
    First, what is this ABS Pump issue? Is it losing fluid? Have you checked the brake fluid level?
    Next, when the vehicle is cold; which is when you say you experience the issue; with the car idling and in neutral pump the clutch pedal and see if the problem goes away after a couple of pumps. If it does then I would start with bleeding the slave cylinder.
    To do this, (very similar to bleeding brakes) have a person sitting in the car. You then locate the bleed nipple for the slave cylinder and undo it. As you undo it tell the person in the car to press the clutch pedal down slowly. Fluid will come out. When the person inside has reached the floor you then nip the bleed nipple back up. Repeat the above until clean fluid comes through and there are no air bubbles (if there are any). REMEMBER to keep an eye on the brake fluid level after a couple of pumps.
    That is a start, when you have done that (or had a garage do it) let us know how you get on and we can go from there.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    If it is like the 6 speed box the cylinder is inside the bell housing and could be leaking, but certainly try above...
    kkk
    Aug 2013
    North London
    109
    i hear ya mate and i do appolagise, this car has turned out to be abit of a dog but i need a car and not chanceing this one at the moment.
    my abs issue is the hydrolic pump according to vag com, iv done the fuses and connector with no result so need to replace that.
    my worry with bleeding is when i tried to bleed a uno clutch years ago the pedel hit the floor and i couldnt get it back lol, did in the end by manully pumping the pedel but still worries me.
    and i do believe the whole unit includes the release bearing but if it was leaking why would it just come back spontaneously when driving, not like brakes when you pump them it builds pressure which is whats confuseing me :/
    and i dint know the 6 speed was the same iv been searching 5 speed probloms i thought the 6 speed was like normal on top.
    so is it just quattros that have it internal?
    thanks guys sorry to be a pain in the as* lol
    Neil
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,275
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by kkk View Post
    It totally is the best forum for the 8L chassis IMO and many others....
    I just have to ask though with the username
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    kkk
    Aug 2013
    North London
    109
    haha the user name became many years back on uk-mkivs when i had my turbo golf, couldnt think of anything that wasnt already taken and had a KO4 turbo sat in front of me and thought im sure no one will have that, lol. and just carried it over on some other forums im on. blame borg warner not me lol :P
    kwistof likes this.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You can bleed the Abs through vcds i think, it is all connected so maybe worth a shot? dont ask me how as ive never done it but there will be info out there....
    kkk
    Aug 2013
    North London
    109
    its the clutch that may need bleeding, the abs is a pump problom cant remember the codes, i use to use a kts 200 to bleed abs units but never liked the golfs, would always stop on the second wheel lol
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    The bleed nipple is on top of the gearbox try bleeding it then....
    kkk
    Aug 2013
    North London
    109
    yea i just sat and pumped the pedel for 10 mins with no change in the feel except a dead leg now lol, i had a look and the part with the nipple on looks quite new and seperates with a clip each side of it so im hoping it will be that it needs bleeding. but the nipple points strait up.
    i dont have anyone to hand to pump the pedel so il have to wait and try that.
    is it not opposite to the brakes that you lock the nipple off with the pedel up instead of down or does the pedel need to be held down when the nipples locked off?
    kkk
    Aug 2013
    North London
    109
    just gonna see if it will gravity bleed but im not convinced with a nipple that points upward lol
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Also have a look on the bulkhead at a round looking junction type box, with pipes coming out, these are known to fail
    kkk
    Aug 2013
    North London
    109
    lol dont get what you mean, for the brakes?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    kkk
    Aug 2013
    North London
    109
    Ehh, manual bleeding dont work, my clutch pedel is now sprung loaded to the floor, this cars starting to wind me up
    kkk
    Aug 2013
    North London
    109
    and that part on mine looks fine no leaks or anything.
    kkk
    Aug 2013
    North London
    109
    iv noticed looking at pictures the gearbox output shaft is quite short, is it possible to slide the box and get at it through the starter hole with small hands and paitence?
    can't drive the car full stop now
    kkk
    Aug 2013
    North London
    109
    looking at a clutch now does anyone know if the G60 flywheel and VR6 clutch fits these like the 2 wheel drive?
    kkk
    Aug 2013
    North London
    109
    update- iv tried useing a taskmaster pressure bleeder to bleed the clutch but i cant get any fluid to come out. the bleeder is building pressure and pressuriseing the resovioer but nothing happening at the bleed nipple :/
    is there anything in the system that would block the flow of fluid.
    i even tried pumping fluid down the bleed nipple with the pedel up but only had a touch of pressure, enough to hear the pedel donk slightly as it drops when the nipples undone but still dont work, which makes me think if i can get fluid through it will be fine.
    any ideas on another way of doing it? iv heard about connecting a tube from the brake master nipple to the clutch nipple and bleed it like that but i dont want to loose my brakes aswell unless someone could clarify how to do it that way.
    banging my head against the wall with this at the moment
    thanks
    Neil
    kkk
    Aug 2013
    North London
    109
    kkk
    Aug 2013
    North London
    109
    im going to buy a gunson but is 2 bar/28psi too much pressure, im thinking the one i have borrowed is only doing a couple of psi.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    2bar is far to high and you would probably do damage to the seals etc, i think i did them at around 15psi but check the instructions
  28. #27
    kkk
    Aug 2013
    North London
    109
    ok thanks was going to try 20 to start but its thats to much im glad you commented, thanks
  29. #28
    kkk
    Aug 2013
    North London
    109
    Pressure Brake Bleeder > Brake Service > Alba Diagnostics > Alba Diagnostics Ltd
    this is what i got any ideas what sort of pressure this runs cause its not enough
  30. #29
    kkk
    Aug 2013
    North London
    109
    right i definitly have a problem but what could it be? i bought a gunson and plumbed it up at 18 psi but not getting any fluid coming out, i disconnected the pipe at the nipple and nothing so i disconnected that block at the back on the left side and still no fluid came out, my tyre went down by the time i finished so i plugged it on my car wheel at 32psi and still nothing. what could be blocking it, i tried with the peddle up and down and tried pumping it aswell. so i guess i have a blockage but what could it be???
  31. #30
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Your pedal has not broke has it? have a look under and see if it is actually pushing the rod? did you check the round valve clutch delay junction thing on the bulkhead?
  32. #31
    kkk
    Aug 2013
    North London
    109
    il have to remove the cover and have a look, it shouldnt of as worked fine sometimes faultlessy. i dont know how to check it, its not leaking and i disconnected the pipe on the side and no fluid came out, im pressure bleeding as well so should get some fluid even at 32 psi surely :/
  33. #32
    kkk
    Aug 2013
    North London
    109
    just checked, pedel and rod all fine :/
  34. #33
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    You have to lift the clutch pedal if its on the floor or no fluid will come out....
  35. #34
    kkk
    Aug 2013
    North London
    109
    yep, wont bleed with the clutch up, iv been trying :/
  36. #35
    kkk
    Aug 2013
    North London
    109
    could the clutch master cylinder be at fault at all and is there any way to check it?
  37. #36
    kkk
    Aug 2013
    North London
    109
    update- FIXEDED IT
    thanks for all your help everyone youve been outstanding :/
    turns out it was the master cylinder must have flipped the seals when the pedel dropped, all seems fine now with a nice light pedel and a little bit of top play as it should be.
    thanks again
    Neil
    s3dave likes this.
  1. 3.0 tdi quattro manual clutch issue?
    By harra1979 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 30th March 2013, 21:54
  2. Clutch Issue
    By iambaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th November 2007, 12:41
  3. A3 Quattro Jerky clutch???
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2007, 00:48
  4. s3 clutch issues
    By S3Matt1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2007, 19:51
  5. Clutch Issues? TDI QS with Revo....
    By TDI_Boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2006, 13:34
