Sky InsuranceAH Fabrications
Results 1 to 1 of 1
    Jul 2011
    7
    S3 apy Logs with Ah fabs V2 Just fitted
    Hi all
    Long time watcher and reader of these forums but now have a 2000 plate apy s3 with a custom code stage 1 map on forge 007p and green cotten panel filter and this last week i have been fitting a Ah fabs V2 cooler, which im very happy with. Quick sum up, choice was either downpipe or cooler at the min and spoke to bill and he recomended the cooler so, with that in mind, ordered it and fitted it this week. I didnt have a boost leak tester so did up every thing as tight as possible, i used Jcs Hi grip jubile clips as tuffy recomends and was pretty happy all is well.
    A few bits i need to change are the boost pipe from the hot pipe on top of the engine to the 1st 90 degree bend as just on the drive reving you could see it expanding and contracing, so under load in sure its much worse. so will get that orderd asap and next will be bills v3 tip. And then get bill to do a custom map on her
    From road testing the car feels good and altho slightly more laggy there is no more feeling of lost power after a hard drive.
    I have graphed the Req vs Act boost and it is slightly below Req but this is exatally the same as pre cooler fitting, it never quite hit exact numbers, so fairly happy, not sure if this is tired turbo or what but hopefully you could give the logs a once over and advise on any thing.
    Best Regards
    Ben
    Sunday 1 September 2013 18:20:16
    8L0 906 018 N 1.8L R4/5VT 0002
    Group A: '002 Group B: '118 Group C: '115
    RPM Load Inj. On Time Mass Flow RPM Temperature Load Absolute Pres. RPM Load Absolute Pres. Absolute Pres.
    TIME TIME TIME
    Marker STAMP /min % ms g/s STAMP /min °C % mbar STAMP /min % mbar mbar
    0.9 1680 60.9 6.97 28.06 0.3 1600 28 0 1030 0.61 1640 46.6 1010 1020
    1.8 1840 94 9.43 35.42 1.2 1680 28 100 1070 1.5 1760 88 2150 1120
    2.7 2080 111.3 11.07 47.03 2.1 1920 27 100 1240 2.4 2000 104.5 2310 1290
    3.6 2400 130.8 12.71 62.69 3 2160 25 100 1410 3.3 2280 124.1 2320 1480
    4.51 2800 165.4 16.4 92.75 3.91 2520 24 95.3 1650 4.2 2640 150.4 2310 1740
    5.4 3280 191.7 19.68 121.36 4.8 2920 24 83.5 2020 5.1 3120 191.7 2340 2190
    6.3 3880 191.7 20.91 139.78 5.71 3480 24 77.3 2270 6 3680 191.7 2310 2270
    7.21 4400 191.7 22.14 167.19 6.61 4040 24 79.2 2250 6.91 4240 191.7 2300 2250
    8.1 4960 191.7 22.14 187.17 7.51 4600 26 80.8 2260 7.8 4760 191.7 2300 2240
    9 5440 191.7 22.96 201.67 8.4 5120 27 84.7 2230 8.7 5280 191.7 2300 2210
    9.9 5880 182 21.73 204.97 9.3 5600 29 88.6 2180 9.6 5720 186.5 2240 2160
    10.8 6240 156.4 14.76 130.17 10.2 6040 30 89 2120 10.5 6160 174.4 2130 2110
    Sunday 1 September 2013 18:14:20
    Group A: '002 Group B: '020 Group C: '115
    RPM Load Inj. On Time Mass Flow Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization RPM Load Absolute Pres. Absolute Pres.
    TIME TIME TIME
    Marker STAMP /min % ms g/s STAMP CF CF CF CF STAMP /min % mbar mbar
    0.6 1960 11.3 1.64 4.5 0.01 0 0 0 0 0.3 1960 11.3 1000 1030
    1.5 2200 93.2 9.43 42 0.9 0 0 0 0 1.2 2120 85 2330 1070
    2.41 2600 120.3 11.89 62.36 1.81 0 0 0 0 2.11 2440 111.3 2410 1350
    3.31 3040 171.4 16.4 106.28 2.7 0 0 0 0 3.01 2880 151.1 2460 1710
    4.31 3760 191.7 21.73 144.28 3.7 0 0 0 0 4.01 3560 191.7 2410 2360
    5.21 4440 191.7 22.14 171.42 4.61 0 0 0 0 4.91 4240 191.7 2390 2300
    6.11 5040 191.7 22.55 189.28 5.51 0 3 0 0 5.81 4840 191.7 2350 2270
    7.01 5600 186.5 22.55 199.44 6.41 0 3 3 3 6.71 5400 191 2280 2180
    7.91 6080 174.4 20.91 199.92 7.31 0 3 3 3 7.61 5920 177.4 2200 2100
  1. Audi S3 APY VCDS logs with remap
    By devil_vas in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2013, 10:37
  2. which TIP for 1999 s3 210bhp apy engine with esp??
    By kaos in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2012, 20:58
  3. How to log with VAG COM.
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2012, 12:44
  4. help needed with my s3 i just got boosting issues!!!
    By joeshutt in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2011, 18:25
  5. My A3 with the CHs just fitted...........
    By Mark_N in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th April 2005, 22:16
