EM TuningSky Insurance
Results 1 to 10 of 10
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Rear Tie Arms and Rear Diff Questions
    My rear tie arm recently snapped. When it snapped it must have pulled the shaft out of the rear diff because it leaked all its fluid over the road. Fortunately the car was stationary and didn't move with the empty rear diff.
    If I am going to change the rear tie bar how tricky is it? Is it pressed into the hub or is it a case of unbolting and fitting a new one or will it need to be done by a garage with a press?
    As the rear diff has leaked everywhere does anyone know if the shaft will most likely go back in with a seal? I can't see the damage very well so hoping someone knows how the shafts go into the rear diff.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,592
    Rear drive shaft should just push back in and lock in place, you will obviously need to top up the diff oil.
    Snapped tie are is very easy to swop over, if you have lowering springs or adjustable tie bars, then you may need an extra pair of hands to push the hub inwards to line everything up.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,391
    Just make sure you tighten bushes bolts up when car is sat on its wheels.
    I.e. how it sits when on the ground.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Mar 2013
    Devon
    617
    If you still have rose joints (now revised by audi to rubber bushes) in the hub where the tie arm bolts to I would check they move freely before fitting a new arm.
    Seized joint is number one reason these cars snap arms and it will quickly fatigue and snap a new tie arm if not sorted.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Mine did exactly this when my tie bar snapped. I could have cried when I saw the pool of diff oil on the road. I got a garage to sort mine out but it did just push in and a top-up of diff oil and had no problems in the 3 and a bit years since.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Thanks for the replies. I'm pleased to hear it will just push back in - even with the pool of diff oil on the road. I will check if it's a rose join or a bush in the arm get it sorted.
    Does anyone know if the top and bottom arms are the same part?
    Many thanks
    8L IS DE BEST
    Mar 2013
    Devon
    617
    Quote Originally Posted by Aaron TDIQ View Post
    Many thanks
    According to ETKA some cars use the same arms top and bottom (1J0 505 323 L @ £72 + VAT ish each)
    But cars with special suspension with PR code 1JF on the data sticker use a different lower arm 1J0 505 323 N.
    These are main dealer or TPS only. Probably best to give TPS a call with your reg, they will sort the right bits for you.
    And the rose joint you are looking for is pushed into the hub not the arm, there are two in each hub for the two tie arms.
    It may have already been upgraded to the rubber bushes though. But defo check before fitting a new arm.
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Quote Originally Posted by JimS3 View Post
    Very helpful, thanks. I don't have the 1JF suspension but I was looking at getting the lower arms with P/N 1J0505323E - are you able to tell how they differ from 1J0505323L as I don't have ETKA.
    Also from this image would it be the Haldex or rear diff oil that needs topping up?
    8L IS DE BEST
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    899
    Add Vex182 on Facebook
    I reckon that is rear diff, very unlikely the haldex oil will be near there, the clutch pack is about a foot forward towards the front of the car.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    ^^ correct you will need Diff oil
  1. torque requirements for rear tie arm inner and outer pins
    By richy1819 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th November 2012, 22:33
  2. Rear Tie Bar and spacers
    By random101 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2009, 05:55
  3. rear suspension arms and bushes
    By audii in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th November 2007, 11:01
  4. Rear tie arms/Camber Adjustment Product
    By Dave_Bayern in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th August 2007, 15:24
  5. adjusting rear tie arms?
    By Banwell in forum Handling
    Last Post: 3rd April 2004, 10:24
