Badger5Monster Motorsport
Results 1 to 22 of 22
Thread: Tyre pressures
    concoursneil's Avatar
    Aug 2003
    Plymouth UK
    327
    Tyre pressures
    Can anyone tell me the tyre pressures i hould be using on 225 40 18's please front and rear as ive just bought new set of wheels
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Oct 2003
    South Wales
    2,942
    Re: Tyre pressures
    36 all round...
    Or try 36 rear, 34 front...
    starski4578's Avatar
    Aug 2005
    Manchester
    147
    Re: Tyre pressures
    I've always put 30 all round!! is it 36? seems alot but i'll change if thats the recomended.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: Tyre pressures
    36/36 is what Audi suggest...
    Personally, I found that awful...too much understeer so I used to run 34F/38R...which gave much better grip and less understeer.
    S3Steve's Avatar
    Sep 2005
    Peterborough
    1,588
    Re: Tyre pressures
    36psi seems very high I would have thought 30psi.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: Tyre pressures
    [ QUOTE ]
    [/ QUOTE ]
    Generally, pressures go up as profile decreases...Audi do say 36/36 for an S3 on 18s.
    30 is far too low to get the back of an S3 to do anything meaningful...you'll need more wind in there to get it into play...
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Re: Tyre pressures
    Hmm I've been told to use 31-32 by most people I've spoken to.
    Will have to look into this.
    elucidate's Avatar
    Dec 2005
    Berkshire, UK
    157
    Re: Tyre pressures
    I run 38 Rear, 34 Front and it makes an amazing difference to the way the car runs.
    Pressure needs to go up as profile goes down.
    I think originally it was here that someone suggested those pressure and boy, what a difference!!
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Re: Tyre pressures
    Wow got to go and try this now.
    Got me thinking.
    Feb 2004
    UK
    1,320
    Re: Tyre pressures
    was going to ask this,nice one!!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,510
    Re: Tyre pressures
    19" wheels, I'm using 35F and 39R, this is good in the dry and track, but crap in the wet!
    Feb 2004
    UK
    1,320
    Re: Tyre pressures
    Got the alloys by the way they look nice,will put them on tommorrow and post some pics.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: Tyre pressures
    [ QUOTE ]
    [/ QUOTE ]
    That's likely to have ben me...
    It's a massive difference in grip, turn-in and reduction in understeer, over standard.
    Aug 2003
    Plymouth UK
    327
    Re: Tyre pressures
    Cheers guys will have to have play with pressures and see whats best
    elucidate's Avatar
    Dec 2005
    Berkshire, UK
    157
    Re: Tyre pressures
    [ QUOTE ]
    [/ QUOTE ]
    It was, thank you thank you thank you!
    World of difference...
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: Tyre pressures
    are we only talking about quattros only or FWD too?
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Re: Tyre pressures
    [ QUOTE ]
    [/ QUOTE ]
    I was wondering this as well.
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: Tyre pressures
    [ QUOTE ]
    [/ QUOTE ]
    Even more so FWD!
    On a quattro you need the rears to give a little to enable them to provide drive...a sliding rear end isn't providing maximum grip...
    On a FWD car the rear only has to follow the front...like a pair of castors really...so it's accepted practice to get the front gripping and then set the rear pressures higher...
    Try the fronts at the setting for 2 people and no luggage (or even slightly less to aid grip, feel etc)...and the rears at the setting for 4 people and a boot full of luggage (or even slightly more)
    That should be a good starting point...
    On the road, I don't like the rears being too high on a FWD car, otherwise it gets unstable and it likely to swap ends if you lift off mid bend...but I do like it to be at the point of breaking away with little provocation to enable the rear to rotate.
    Lift off oversteer is great if you have lots of grip at the front (aggressive suspension angles, sticky tyres and an LSD - which I do) but no use if you can't power out of the slide you have put the car in....so be careful how high you go on rear pressures.
    I can't remember what I run my Golf at...something like 30F/35R or 32F/36R, somewhere around there. That's on 215/40/16s on 7" x 16" BBS wheels.
    I'd know if I saw what the Mk3s run standard...but that's in the right ballpark.
    Play about though...
    Aug 2005
    Manchester
    147
    Re: Tyre pressures
    Interesting stuff, i will be giving it a try soon as. Have always gone for 30/30 on all my other cars but sounds like it can make a massive difference. Cheers
    SilverBullet's Avatar
    Bullet
    Nov 2006
    Istanbul, Turkey
    11
    for 225 45 17 ?? my pressure is 32 is it fine?
    SilverBullet
    thinking about stuff
    May 2006
    Leeds
    599
    higher pressure = less friction (grip)
    lower pressure = more friction (grip)
    Basically experiment front to rear to you find a balance your happy with. F1 cars run 1.1 bar which is about 18psi!!!
    2001 Black RS4 - P11 LCC
    1992 Burgundy Pearl Corrado VR6 - A20 LEE
    A3_Turbo's Avatar
    Swaying towards IHI....
    Jul 2006
    Virginia water, surrey
    1,441
    Yeah I used to do alot of racing myself, And the general rule is lower PSI more grip but your tyres wear quicker, and the opposite way more PSI less grip because less rubber is being laid down and your tyres dont wear as much.
    So when racing you change your pressures according the the car set-up, Weather and how many laps. Some times when it was hot, and too much grip being laid down you'd find it hopping.
    Im going on a bit there as you dont need to know that, but unless your driving your car hard you wouldnt want to change from what audi suggests surely?
    But then if you are just experiment there is no right tyre pressure it has to be what feels right for you. For example some-one may like understeer and say use 28-32 you may not like understeer so it wouldnt be right for you.
    Just try and experiment a few different combos.
    But as i said if your not driving the car hard just poodling to work then you dont need to worry you'd probably be better off putting what audi sugest as all you'll just be worried about is tyre wear if your not driving it hard.
    Rant over.....
    Jason
    A3 1.8TS
    K03S,Pro Alloy FMIC, Neuspeed TIP, Forge 007P,Jabba Stage 2, BMC CDA, Turbo Back Miltek,H&R Cup Kit,H&R Arb's,18" Cup 3's Wrapped in Parada Spec 2's, Facelifted, 10k Hids, Dewipered, Debadged,S3 Interior, S3 Rear bumper, S4 Front bumper, Brembo's, Momo Team, LCR Splitter.
