Badger5Chris Nott
    Aug 2013
    21
    Best place to buy forge gear from ?
    Hi Iam sure there is a thread about this already but I've had a look and I can't find it
    also has anyone changed an agu 1998 to 6 speed (new box ) is there a way of doing it ?
    Thank you
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,083
    Visit 16Klappe's Instagram Channel
    Why on earth would you ever want to swap from 02j to 02m?
    Just fit a facelift 02j gear linkage and all your woes will be gone.
    I quite often say I'm going to do things.
    Then never do them.
    Aug 2013
    21
    Just want one more gear
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    Oddly, I'd have to agree with Jardo. I'm buying a decent clutch and flywheel at the moment and already got a wavetrac diff, both parts are way more expensive for an 02M compared to the others. Not worth it to say you have a six speed.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,083
    The over all final ratios are as good as the same, but having the wider spread in the 5 speed lends itself to the torque of our cars.
    An 02M will basically make your car slower and cost more.
    Why do you want an extra gear?
    Then never do them.
    Aug 2013
    21
    Okay sweet , just a cruising gear at like 80 for better ratio
    also I brought my Audi with clutch gone so I repaired the clutch (standard one) and the left front wheel had negative camber so I changed the front bed out of my 2001 Audi and replaced steering rack as my track rod end was bent and fitted coil overs (eBay ones) and it has improved the camber alot but there is still a tiny bit there any ideas what it could be . Has anyone heard of the hubs bending ?
  1. Best place to buy rear wiper motor apart from audi?
    By xyz1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th July 2012, 18:01
  2. Front Splitter .Wheres the best place to buy one from?
    By S3 JOHN in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2012, 17:00
  3. best place to buy S4 arb from??
    By rich1973 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd June 2011, 09:49
  4. Best place to buy new gear/shift knob & Handbrake grip
    By Dan76 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st March 2010, 21:10
  5. best place to buy a late coupe fuel pump
    By lazzaman in forum Classic Audi Forum
    Last Post: 25th November 2006, 21:48
