JMB RetrofitsBadger5
Results 1 to 8 of 8
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Replacing Rear Brakes (brake sensors?)
    If anyone could greatly leave some useful infomation hear. I have managed to source a set of disks and pads for the rear as they need changing
    Is there any inportant points I should take into account before attempting this job - replacing them on a 106 was fairly simple and not yet attempted them on an Audi A3.
    Cheers in adavnce!!!
    OLD QUESTION
    Does the AUM 1.8T sport version have these does anyone know?
    Because it turns out that my A3 doesn't to answer the question personally and now I need to urgenty buy some brake pads to tie me over until I can actually afford some new disks
    If I could get an answer as soon as possible it would greatly appreciated. Regards
    Kristian
    No longer an Audi driver...
    dusty's Avatar
    Nov 2010
    nw england
    144
    Have a look in the stickies at the definitive brake thread should tell you in there
    2001 s3, stage 1 amk, nogaro blue, bilstein shocks, eibach springs, forge adjustable tie bars, Red power flex dog bone bush, Awesome heavy duty clutch, 18" nouvalari alloys, ambient lighting, tt pedals, led side lights, led number plate lights, abt number plate surrounds, badger 5 tip, jetex filter, resonated milltek cat back exhaust, bailey dv,
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    878
    Add Vex182 on Facebook
    I don't have any sensors on the rear of my s3, only 1 on the front passenger side.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    no sensors...
    <tuffty/>
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Cheers guys! Can't understand the point of having all this ABS technology and only one wheel with a pad sensor lol
    Kristian
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Right guys, I have just updated my original post with an question of advice - if someone could repsond I would be really appreciated! :D
    Kristian
    dusty's Avatar
    Nov 2010
    nw england
    144
    You will need a wind back tool for the rear calipers, to screw the pistons back into the calipers before fitting new discs/pads
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    All sorted
    Kristian
  1. Brembo brakes and brake pad sensors...
    By imported_MattT in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2011, 07:48
  2. Rear Brake Pads - which brand
    By g60leigh in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th June 2008, 09:14
  3. Rear brake pad change...
    By oversteer in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th August 2007, 14:21
  4. Changing rear brake pads (A4 Avant)
    By NickB in forum General Technical / How To
    Last Post: 4th November 2006, 16:38
  5. damaged brake pad sensor
    By beerglass in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th October 2006, 15:55
