Volks AutosEM Tuning
    Jul 2011
    peterborough
    33
    i used the stickies :) but still stuck :(
    I wanted to know what the maximum power I can run from a standard "AGU" head and using the stickies section I found an answer.
    "Good info but you need to add valves to this list as the standard ones are 2 piece valves and are good for 350bhp ish before the heads break away from the steam."
    But when reading it says its from an "AEB" not a "AGU" head so I still not sure so if someone can point me in the right direction I be grateful.
    Adam
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    The head will be good for 400 ish hp un-ported (will do more but porting will benefit the overall reliability and power output...), its revs that kill std valves not power... to reach that power level though you will need a big turbo and then it will need to rev... so up to 350hp you shouldn't need to go much higher than 7.2k to 7.5k as turbo at that power level don't make the power at high enough revs... to make the valve train more durable at higher revs then you would need valve springs and decent valves... (supertech for example)... you can rev to the moon with that setup..
    Worn valve guides are also an issue on these heads... exhaust guides wear, valves flap about at high revs, heads drop off, bad times ensue...
    <tuffty/>
  1. used k seal but still a slight leak?
    By MR B A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2011, 15:10
  2. changed my lambda sensor today but still got the faults
    By s3gazz in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2011, 21:26
  3. New turbo fitted but still the noise remains.
    By Turbo Lag FTW in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th August 2009, 15:19
  4. Aftermarket Head Unit but still use my Bose
    By brixo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st June 2008, 23:49
  5. Not an Audi but still part of the family
    By james b in forum Detailing
    Last Post: 22nd February 2008, 11:56
