AH FabricationsVolks Autos
Results 1 to 8 of 8
    Dec 2005
    UK
    98
    What\'s everyones opinion of Redex Fuel Cleaners?
    I've used the standard Redex fuel treatment cleaner (the add straight to fuel tank method) in previous cars.
    Do people consider worth using on a regular basis with fuel? Do people get better performance and economy through using it?
    I'm thinking about running it through my 1999 Audi A3 1.8T to clean up the carbon deposits that build up over time to make sure I'm getting optimum perfomance!
    Buster's Avatar
    Dec 2005
    Aberdeen
    169
    Re: What\'s everyones opinion of Redex Fuel Cleaners?
    Never used it and would never use it
    Nov 2004
    London UK
    2,614
    I have used the STP multivalve cleaner and also the Injection cleaning fluid. Need to again soon. I do notice that the engine is slightly smoother after wards. I personally would recommend doing it. As long as it aint that octane up your bhp crap i hear that eats away at your valves and piping
    Grant's Avatar
    Dec 2003
    Aberdeen
    1,045
    Modern fuels have cleansers in them, so you shouldn't have to use these products.
    Oct 2003
    South Wales
    2,942
    I'm sure there was a post some time ago which said you shouldn't use it. I cant remember why exactly but you should investigate it further if you are thinking of using it.
    imported_VaulterTim
    Agreed... I wouldn't just bung it in and hope for the best. It used to work wonders at cleaning older carb.-engined cars that ran on leaded fuel but on todays cars I'd be a bit sceptical...
    Anito's Avatar
    Dec 2003
    Chester
    429
    IMO, If your using decent petrol in the first place then there is no need. I always use Optimax and a mate who runs a garage has asked me to try a couple. The result? Not even the smallest difference.
    Khufu's Avatar
    West coast of Scotland
    5,693
    'proper' petrol has detegents added to keep the engine cleaner, cheaper (supermarkets) petrol doesn't. People say that petrol is all the same etc. This is right, but its what they add that makes the difference.
