Sky InsuranceChris Nott
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Scullies
Thread: Stripped oil drain sump bolt - repair options?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    So I have been battling along with a stripped oil drain bolt and been thinking about repair options.
    Option 1 - weld a npt fitting into the sump then use a Allen head npt plug to seal it off.
    Option 2 - weld a AN O-ring fitting into the sump and use a AN O-ring bolt to seal it off.
    Anyone tried one of these ideas with a positive result?
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Would it not be easier to source a 2nd hand sump via eBay.
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    But it's only going to suffer the same fate at the hands of ritard mechanics that change oil. Looking for a ritard proof system
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,352
    The problem with are sumps is the drain plug is 17mm or is it 19mm and as you said retarded mechanics get giddy with the air ratchets when doing them up
    Weld in a bung and re-tap it for a smaller thread and bolt size?
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    shariain's Avatar
    May 2004
    Glasgow
    1,170
    Well if you are letting retard mechanics fix your car find another garage.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    The idea was to drill out the damaged thread, fit a flanged bung into the hole and weld the flange on the outside of the sump.
    Not sure if NPT is the way to go or if O-ring is better
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Quote Originally Posted by shariain View Post
    as far as I am concerned they are all retards that don't care about your car. I only let them do the oil changes, the rest I do myself.
    S321BAM's Avatar
    I lost the rod lottery
    May 2010
    Plymouth
    101
    Could repair it with a heli coil? Would of thought they done them that size. Heli coils are basically springs, you tap the thread bigger for the outside of the coil and the inside coil becomes the new thread for your plug
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    I thpught the title meant turbo oil drain. Ive got an an10 boss welded on for that.
    Maybe do the same for the sump plug
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    Just worried a male AN fitting with a cap on the end will stick out too far and get damaged or knocked off by a speed hump.
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    717
    Wouldn't it be much easier to just find a new/used sump and change it and then find a competent mechanic to maintain it and not bugger up the threads again.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Scullies's Avatar
    Feb 2012
    Dubai
    1,203
    In Dubai the garages hire cheap labour to do the dirty work, now these people couldn't give a f#*k, they just do their time for their money.
    You will never find a garage here where the owner actually works on cars, they all think they are fat cats and sit in the office shouting orders, while they charge you premium rates and pay minimum wage.
    Even the dealers are a joke, when I go looking for parts,I have to show the sales guy how to use the parts catalogue! I refer to them as new parts fitters, they just fit new parts till the problem is solved.
    audiholic ste's Avatar
    Aug 2013
    163
    As someone said above fill the hole up with weld and rethread with a tap the same size as the sump plug .
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,637
    Change the oil yourself you lazy git
    I had similar (ECS magnetic sump plugs are ****e) and fitted a new sump and stuck to OEM sump plugs. Alternatively ECS sell the little "taps". I had one but it stuck out a bit...
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  1. Where is the oil drain plug?
    By hodgy0_2 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd August 2009, 12:45
  2. stone chip repair - options/suggestions
    By Slipp Digby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2009, 18:42
  3. Magnetic Drain Sump Oil Plug Help
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2009, 10:54
  4. Help! Stripped head on Hex Bolt
    By chasdrury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th September 2008, 12:02
  5. gearbox oil drain plug special tool
    By adrian2006uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2007, 14:24
