AH FabricationsEM Tuning
    Aug 2013
    50
    Need your advice please fellow s3 guys!!
    Hi guys was looking under the bay of my 2001 s3 and I just happened to wipe my finger around the forge DV to fun oily deposits?! Where can I find out where this is coming from? Any help would be excellent! Thanks
    Big Al's Avatar
    A4 2.0T FSI engine knackered!
    May 2011
    West Midlands
    304
    Check the rocker cover breather outlet tube joiner S shaped bit - not sure what it's called! But they often break around there?
    Audi A4 B7 2004 red 2.0 TFSI Quattro Sport saloon, Servotronic steering, MFSW, CDIS, DRL with Coming Home, auto dual xenon lights/wipers/mirrors, split folding rear seats, 3rd headrest, centre armrest, Isofix mounts, RS4 rear ARB, pedals & carbon dash trims; Audi TTS 9Jx18alloys (2 sets), Yokohama AD08 summer, Conti TS830P winter 245/40/18 tyres, TPI 15/20 spacers/lockers, Pipercross filter, GFB DV+ turbo valve, NGK BKR7EIX plugs, Osram Silverstar Xenarc D1S bulbs. Build thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,583
    tbh it could be coming from several places based on your description... one thing to note is oil should be on the inside of the engine rather than the outside... if all the gaskets and stuff are doing their job then there will be no oil anywhere..
    Pics would help as it could show if it was transfer from a leak or leaking out the DV... the DV is far enough away that a typical 'leak' won't be able to transfer to the DV... so its ether leaking from the DV or being blown on the DV... this suggests pressure is involved... look for signs of fresh oil rather than the congealed stuff thats a sign of a long term leak...
    Clean the area with brake cleaner and see what comes back... be easier to spot where the oil is coming from too...
    Anything rubber can rot and split so check all the hoses... 007's leak so make sure the top is tight and any hoses connected to it...
    Pics next time
    <tuffty/>
  1. Need some advice please guys
    By Heti in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 29th July 2012, 21:52
  2. Replies: 21
    Last Post: 1st September 2010, 22:43
  3. Is this worth it, need your help please guys
    By TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th November 2005, 13:03
  4. Married blonde - need your help please
    By mark88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th October 2005, 19:59
  5. I really need your advice people!!
    By JamS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th September 2005, 21:50
