Volks AutosChris Nott
Results 1 to 13 of 13
Like Tree2Likes
  • 2 Post By 16Klappe
Thread: Help needed please slight problem a3 1.8t
    Aug 2013
    36
    Morning all,
    I have got a slight problem with my a3,
    When the car is at idle every so oftern it seems to almost giv like a little jump/misfire also when i am driving and giv it the boot it seems to be holding back/misfireing agin Also useing a load more fuel all the time.
    Have replaced the plugs seemed to help a little but it is still happening, Would this be a coil pack problem or the ignition amplifyer or at a long shot could it be a blocked fuel filter
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,098
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Sounds like the symptons of a tired MAF -
    Unplug it and see how it runs on idle then
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Jul 2013
    Uckfield
    72
    Follow fanta On Twitter
    Also make sure you've got the air con off. I made a schoolboy error thinking there was something wrong when using the demisting blower
    Aug 2013
    36
    Quote Originally Posted by fanta View Post
    Air con defo not on
    Aug 2013
    36
    Anyone else got any idears
    Jan 2012
    Halifax north west
    14
    I agree with kwistof start with the the maf, have you checked for codes?
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,898
    Visit 16Klappe's Instagram Channel
    Quote Originally Posted by xxxxSMITHYxxxx View Post
    http://m.dictionary.com
    hendry10 and Pubemammal like this.
    I quite often say I'm going to do things.
    Then never do them.
    V.A.G.erbond's Avatar
    Spooling
    Nov 2012
    Leeds
    129
    Definitely MAF had this prob on my Cupra (same engine) bigger turbo. Codes should show it up but you should check or clean ur MAF first before replacing. Brake cleaner works to remove deposits ( aerosol) work a try before replacinf
    Aug 2013
    36
    What is the best way to get to the maf do I remove just the small bit connected to the cables or remove the hole plastic cone type unit c
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    Do the standard checks... scan for fault codes, visually checks for split pipes (normally under the inlet manifold) and if you can get a smoke test done...
    This symptom is typically airleak related as it messes with the mixture... you haven't mentioned the car you have... saying its a 1.8t isn't enough... would appear you have a TQS from your previous posts so its a narrowband ECU with drive by wire throttle...
    Unplugging the MAF and driving like that to see if the problem is still there should eliminate it as a possible candidate... I personally think its an airleak but if the MAF has not been changed to your knowledge its worthwhile bunging a new one on as a service item regardless...
    Scan with VCDS and if you have access to a registered version check block 032 while the engine is idling... do not clear any fault codes prior though as the fuel trims will reset
    <tuffty/>
    Aug 2013
    36
    <tuffty/>
    ok will do the is for the info, could a low voltage battery be the cause of a fault like this?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,016
    No sure what you mean but if the alternator is not kicking out over 13 volts then running problems can happen... but rather than stabbing in the dark I suggest you start with the diagnostic process I suggested and work from facts
    <tuffty/>
    James TQ's Avatar
    Apr 2012
    Essex
    546
    money on it being a lambda sensor in the exhaust, i had the same problems, if the sensor is gone it cant get the exact reading so over/ under fuels
  1. New S3 Sportback door mirror problem...help needed please?
    By wright1965 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th September 2012, 09:57
  2. Brake problems, Help needed please. :(
    By Harribo66 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2012, 22:47
  3. Help needed please.... B5 AVANT SLIGHTLY MODDED
    By Steve B5 Biker in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th May 2012, 09:35
  4. Problem with Temp Warm-Up(Help Needed Please)
    By THE MONSTER in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd February 2010, 12:22
  5. HELP NEEDED PLEASE
    By RAV in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2004, 11:58
