Sky InsuranceEM Tuning
Thread: Using water
    Aug 2013
    12
    Using water
    Hey all
    Just noticed my a3 uses water need to top it up every 2 weeks as it drops below min
    I asked the father in law who I bought it off
    And he said it's done that ever since he had it which he owned for 2 years+
    He had it in a vag specialist and they could not find anything
    I am assuming headgasket? The oil is ok and not getting water in
    Is they any common areas to look at so far I have checked oil
    All hoses and radiator.
    They is no leaks on the drive
    Jan 2011
    northants
    165
    what engine?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    Are you using water or do you have proper coolant in there? if using the correct G12 variant then it will be obvious if there is a leaking pipe somewhere... G12 leaves nice pink stains...
    <tuffty/>
    Aug 2013
    12
    Sorry it's a 1.8t 2000model I am not 100% sure if they is coolant in just looks normal dirty water could I not put a dye in the water so I don't waste coolant
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,547
    Quote Originally Posted by ROBA3T View Post
    Should be using a proper G12 coolant really dude.. you want to go to a local garage for a hydrocarbons test... that should determine if the headgasket has gone... fairly rare tbh as they are quite sturdy but cracked heads are fairly common...
    <tuffty/>
  1. Burning oil and using water
    By Tony gold in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2013, 10:33
  2. car using water
    By mtwallet28 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th November 2010, 20:22
  3. S3 using water after head gasket been done help ???
    By a20 hvy in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2010, 18:08
  4. 2.0 TDI Using WATER (COOLANT)
    By stevehsv868 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th October 2007, 19:11
  5. Using Water/Coolant
    By tominski in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2007, 18:52
