Badger5Volks Autos
Results 1 to 30 of 30
Like Tree4Likes
  • 2 Post By 16Klappe
  • 1 Post By 16Klappe
  • 1 Post By Prawn
Thread: a3 1.8 t tuning with mileage around the 100k plus mark?
    Aug 2013
    east sussex
    12
    hi everyone im looking into buying a a3 1.8 ,
    but they all seem to be 100k plus unless you want to spend alot more on one thats less than 80k.
    so i was wondering if you can still modify i.e uprate the turbos etc with mileage over 100k
    just wanted your opinions and advice
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    my mates 1.8t sport ko3s is at 165000 and has been running on a stage 2 amd map with a 26psi boost spike settling to 23psi for 2 years making 208bhp and 247bls or torque... stock intercooler aswell!!! seems fine, guess it depends on the history but my mate drives it like he stole it lol!
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,068
    Visit 16Klappe's Instagram Channel
    Arn.
    Please stop giving advice.
    26psi on a K03 is not fine.
    Especially not on a stage 2 map, with a standard intercooler at 26psi.
    I quite often say I'm going to do things.
    Then never do them.
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    lol, i didnt mean its fine to do that, i guess i should elaborate more!-) its not blown up, although it does show they can still take serious abuse at high mileage.
    Aug 2013
    east sussex
    12
    i just want to find one thats been looked after but obviously i dont want to up the bhp and then it blows up because of the high mileage.
    i read somewhere that the 1.8t engine is seriously strong and can take alot of power , so the ones ive been looking at are around the 110k-130k mark so hopefully these engines can still take the power with this mileage
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    879
    Add Vex182 on Facebook
    The engines are pretty strong, the issue is only reall that the conrods can give in around the 300bhp / 300lb-ft mark. Some have worked fine and on some cars, they have bent / snapped at less.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Aug 2013
    east sussex
    12
    well i was thinking tuning to around 250 bhp but do you think that would be ok on one thats done around 120k? couldnt you change the conrods if you wanted to go with more power ?
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    im sure klappe said to me 275bhp and 275bls of torque is safe-ish on an s3 but i believe ko3'd cars have slightly thinner rods, dunno if they can take the same?
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    get a car with a ko3s as standard and you can make close to that bhp and monster torque on the standard turbo, the guy who posted above klappe has one of if not the fastest 1.8t on this forum!-)
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,068
    AGU cars have 20mm wrist pins and are just as strong as any S3 engine.
    Whether your car will blow up or not is a total lottery, nobody can put a time power or age limit on it.
    My car for instance is 245bhp and 319lbft, totally stock internals and producing far more torque than any K04 car, and is the most "powerful" K03s cars on this forum and one of the most powerful non-meth assisted K03s cars in the country. And it's torque which bends rods, which mine has a lot of.
    It's on 125K, original turbo and actuator. And is perfect.
    My last car was on 192K, and was also totally stock internally. And had never had the head off it; it was a "genuine" stage 2 car with circa 230bhp and 290lbft.
    Was perfect.
    Prawns car managed 210,000 without the head ever coming off it. Also a 230bhp/290lbft K03s.
    I've had friends with 80,000 mile 220bhp A3's bend rods. Because they were mapped by clowns.
    Take your car to Niki at R Tech, or Bill at B5 and you can be sure that your software will be perfect. So all you've got to think about then is your hardware, which is the smaller half of the battle.
    Then never do them.
    Aug 2013
    east sussex
    12
    thank you for the info that really helps
    i no that the pre 2000 a3s have larger ports ? so there better engines ?
    theres so many engine codes it confuses me ! lol
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,068
    No benefit on a K03 car, just loses torque.
    AGU = ME3 ECU, no boost monitoring, no map sensing, three wire bolt down coil packs with separate ignition amplifier, 20mm wrist pins and a large port head. Also has a gay K03 turbo.
    AUM = ME7 ECU, boost control is much more accurate, tuning options are far more technical and adjustable, push down coil packs, 19mm wrist pins and small port head. Slightly less gay K03s.
    I'm sure I've written all of this out before haha.
    Must do modifications for K03/K03s AGU and AUM engines FWD cars
    kwistof and JudderMan like this.
    Then never do them.
    Aug 2013
    east sussex
    12
    thats really good infomation thank you for your time , i have to think agu or aum? lol
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,068
    Six of one half a dozen of the other.
    If you could have an AGU with AUM management, win.
    Then never do them.
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    my vote is for AUM just gonna repeat the above really, basically millage is kinda irrelevant its more the history and more importantly getting it mapped by decent tuners regardless of where you live, R-Tech or badger 5 is worth the trip
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    Aug 2013
    east sussex
    12
    well ill hopefully find a decent a3 with good service history, then i can go from there , ill try and figure out how to do a build thread once i start.
    could i ask what is the performance like at around 230/250 bhp ? i
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Quote Originally Posted by adama3t View Post
    Jardo has many videos, go through his posts and you'll find them. It looks brutal.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,068
    adama3t likes this.
    Then never do them.
    Aug 2013
    east sussex
    12
    thats quick what bhp was that running klappe?
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,068
    Was 245 and 319 at last rolling road, but as always it could be anything.
    Not the fastest car in the world ever, but great for a daily driver.
    Then never do them.
    Aug 2013
    east sussex
    12
    no but that is still good what was the 0-60 time roughly ? thats what i want a good 0-60 time
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,366
    My car for instance is 245bhp and 319lbft and producing far more torque than any K04 car,
    Bad Jardo. don't tell lies.
    slowcoach3 likes this.
    Aug 2013
    Hi There I have audi a3 agu 1.8t iv put on a Forge recirculating valve 0008 and a piper cross panel filter. I want to go all the way when it comes to tuning just wondering what else can I do and also if you put an induction kit do you completely take off the ignition amplifier module because this is causing me problems as am assuming the dirty jerking of the car is because of that.? PLZ HELP!!!!
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,277
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by Elitecarz2011 View Post
    Hi There I have audi a3 agu 1.8t. I want to go all the way when it comes to tuning just wondering what else can I do PLZ HELP!!!!
    There is a perfectly good link within this thread that has already been mentioned....
    I'll give you a clue- it's in post #12 ;-)
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Think about it dude... the ignition module is required for the coils to actually work... your 'jerking' sounds more like an airleak or dodgy MAF
    <tuffty/>
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    on the video he's already moving when it starts then at 60 around 5 sec, i'd say around 5.5sec?
  28. #27
    Aug 2013
    east sussex
    12
    these cars seem to have so much tuning potential so much fun . there really well built too not like rattly japanease cars or especially the french cars haha
  29. #28
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    693
    Hate to say it but if I was gonna go fwd I'd go golf or leon cupra r myself. The leons look much more modern than our old gals!-)
  30. #29
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,068
    I don't like LCR's.
    They are much heavier, cost three times as much, have too many doors and portray a shocking image unless tracked up
    Then never do them.
  31. #30
    Aug 2013
    east sussex
    12
    I had a cupra before 2001 reg 1.8 t hated it it felt too heavy and tbh I couldn't deal with the big "S" badge on my car lol,
  1. Replies: 9
    Last Post: 7th March 2013, 12:23
  2. HELP with mileage!
    By Pez in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th September 2012, 22:26
  3. Replies: 28
    Last Post: 18th January 2011, 19:03
  4. Replies: 28
    Last Post: 4th December 2010, 17:04
  5. Brokers who deal with dealers in the South?
    By cdb2 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th September 2004, 16:43
