Badger5EM Tuning
    nath-w's Avatar
    Mar 2009
    134
    Possible timing belt issue? Help!
    I have a 2003 1.9 TDI with 145K on the the clock. I have just returned from a trip to Cornwall and noticed that on tick over there was a horrible sounding rattle coming from the engine. When I investigated I noticed that one of the pulleys or tensions for the cam belt is moving slightly back and forwards. I immediately panicked and turned the engine off. I am just wondering is there a way that you can tighten this back up, or as its an important component should I just have it replaced along with the cam belt at the same time, as I presume the cam belt would have to be removed anyway to replace it. Any suggestions would be much appreciated.
    Also I thought I should mention that I only bought this car a few weeks ago from a dealer with 3 months warranty, so would this be covered by the warranty?
    I have taken some photos below to help describe what I am trying to explain.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,474
    its ment to move
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    That isn't the cambelt tensioner - it's the serpentine / auxiliary belt tensioner. As already stated it is meant to move with the vibrations to keep the belt tight.
    '02 A3 TDI quattro sport
    8L IS DE BEST
    nath-w's Avatar
    Mar 2009
    134
    Oh okay, sorry for my incompetence. I obviously didn't look at it properly . Obvious now you said it, first clue is the fact that threes no teeth on the belt.
    yeah it moves back and forth on tick over, but the rattle is very loud now? It wasn't this loud when I bought. Is the easiest fix just to replace it, and is it an easy job?
    bez101's Avatar
    Jul 2008
    8,474
    take it back to the dealer you bought it from
    get them to sort the problem i may not be that and something eles
  1. B6 Timing Belt Issue - 1.9TDi (PD - AVF)
    By Dibs_h in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st October 2012, 22:36
  2. Timing belt issue
    By iamwhatiammomo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd June 2012, 02:29
  3. HELP how do you tighten the timing belt tensinor
    By hoban81 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2010, 15:40
  4. Timing Belt issues
    By dsoares in forum General Technical / How To
    Last Post: 13th October 2008, 22:51
  5. timing belt issue
    By hdailey in forum TT/TT-S/TT-RS Forum
    Last Post: 12th February 2004, 22:07
