Chris NottJMB Retrofits
    Jul 2007
    27
    S3 brake fluid warning light!
    So the story goes - I changed the front brakes on the S3 yesterday as they were as good as wafers! This cleared the pad sensor light that I had on the DIS but I now have the brake fluid warning light!?
    Did lose any fluid and I would have thought that depressing the calipers to fit the large brakes is likely to raise the fluid level?
    Could the sensor be throwing an error if it is over full? or is there something else to check?
    Any help welcomed!
    Jan 2011
    northants
    165
    did you remove the cap when you pushed back the pistons?
    you can get brake fluid into the cap and it coats the terminals etc
    remove the cap and suck out to correct level and clean out the cap with brake cleaner
  1. brake pad warning light
    By avanted in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th October 2008, 00:59
  2. brake pad warning light
    By jays3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2008, 10:22
  3. Brake system warning light - ABS related?
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2008, 03:16
  4. Brake pad warning light reset???????
    By 46TheDoctor in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th April 2007, 08:27
  5. Help? Washer Fluid warning light perm' on
    By imported_matesgotanA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th July 2004, 09:19
